S-Flex 1200RPM X2 vs S-Flex 1600RPM X2 with Prolimatech Megahalems
I probobly will buy the Prolimatech Megahalems CPU cooler in a couple of days and want to attach to it 2 Scythe S-Flex'es in a push-pull configeration, But don't know which S-Flex'es to choose.. The 1200RPM's or 1600RPM's? I am going to overclock my Q6600 to 3.6GHz and I need alot of cooling.. Will I feel a diffrence between the 1200RPM and the 1600RPM? If so can you assume if the diffrence is going to be minor or major? If it's going to be a 1-2 degrees diffrence between them then I'll go for the 1200RPM, since it's much more quieter but if it's going to be a 4+ degrees diffrence then I'll go for the 1600RPM's..
Can you assume?
Thanks.
פותח התרד אף אחד לא יכול לנחש..מין הסתם שעם ה1600RPM התוצאה תהיה טמפ' נמוכנה יותר בכמה ? מביקורות שונות..כמה מעלות בודדות..
זה כבר שיקול שלך מבחינת רמת רעש וכו..
Yeah I thought about it.. I think prob about 2-4 degrees, which isn't worth the noise.
