אוזניות בתקציב ~ 200 ש"ח
I would like to buy earphones, these are the 2 things that are important to me:
  • Noise Cancellation- I will be using them on the bus.
  • I will be using them while running.
Here are the ones that I have considered, but you may have a better one:
Sennheiser HD 457
Creative EP630
Skullcandy inkd
Sennheiser CX300b
;D
Thanks!
(You can answer in Hebrew)
