3 כרטיסי SDRAM
שלום,
ברשותי לוח אם עם שלושה סלוטים מנוצלים לכרטיסי זיכרון.
כל אחד מהם בנפח 128MB, שניים 133MHZ ואחד רק 100MHZ.
לפי התוכנה CPU-Z, אלו הם נתוניהם המדוייקים:
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type SDRAM
Manufacturer (ID) (0000000000000000)
Size 128 MBytes
Max bandwidth PC133 (133 MHz)
Part number
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-6-0 @ 133 MHz
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 80 08 04 0C 09 02 40 00 01 75 54 00 80 08 00 01
10 8F 04 04 01 01 00 0E 00 00 00 00 14 0F 14 2D 10
20 15 08 15 08 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 9D
40 00 00 00 00 00 00 00 00 07 00 00 00 00 00 00 00
50 4F 38 39 39 30 30 31 37 00 00 00 00 00 00 00 00
60 00 00 00 4D 33 38 45 31 32 38 53 38 38 50 51 4E
70 41 37 35 00 00 00 00 00 00 00 00 00 00 00 64 FD
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
DIMM # 2
SMBus address 0x51
Memory type SDRAM
Manufacturer (ID) Kingston (7F98000000000000)
Size 128 MBytes
Max bandwidth PC100 (100 MHz)
Part number KGM100x64C2/128
Serial number 28060020
Manufacturing date Week 33/Year 99n
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
JEDEC #1 2.0-2-2-5-0 @ 100 MHz
JEDEC #2 3.0-2-2-5-0 @ 100 MHz
SPD registers
00 80 08 04 0C 0A 01 40 00 01 A0 60 00 80 08 00 01
10 07 04 06 01 01 00 0E A0 60 00 00 14 14 14 32 20
20 20 10 20 10 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 8E
40 7F 98 00 00 00 00 00 00 02 4B 47 4D 31 30 30 78
50 36 34 43 32 2F 31 32 38 00 00 00 00 00 63 21 28
60 06 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 A6
DIMM # 3
SMBus address 0x52
Memory type SDRAM
Manufacturer (ID) Micron Technology (2CFFFFFFFFFFFFFF)
Size 128 MBytes
Part number THMY6480F1BEG-80
Serial number FFFFFFFF
Manufacturing date Week 255/Year 255n
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
JEDEC #2 3.0-3-3-7-0 @ 133 MHz
SPD registers
00 80 08 04 0C 0A 01 40 00 01 75 54 00 80 08 00 01
10 8F 04 06 01 01 00 0E A0 60 00 00 14 14 14 30 20
20 20 10 20 10 FF FF FF FF FF FF FF FF FF FF FF FF
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 12 C3
40 2C FF FF FF FF FF FF FF 03 54 48 4D 59 36 34 38
50 30 46 31 42 45 47 2D 38 30 20 20 00 00 FF FF FF
60 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 64 A7
בתוכנה Everest כתוב שה-Total ב-Physical Memory שלי הוא רק 255MB
וב-Task Manager כתוב ב-Phisical Memory שה-Total הוא 261620, מה שלהבנתי אומר 256MB.
מישהו יודע להסביר לי את הבדלי הגרסאות?
האם יש להסיר את רכיב הזיכרון שמתאפיין ב-100MHZ?
תודה רבה!
לא צריך זה בסדר..
עיגול כלפי מעלה/מטה.
ואני לא חושב שיש צורך להסיר.
