Max temp for E8400 @ 24/7
I'll buy a new motherboard soon and i want to OC my E8400 to the max 24/7
what is the min/max best temp for 24/7?
btw how far can i reach with E8400
Asrock P45XE
and a good memory with 1066mhz ( probably g.skill/ocz/mushkin/crucial ) tnx
and what is the max temp if i want to Extreme OC to check SPI / 3DMARK/ VANTAGE etc...
tnx
what is your cpu cooler curently installed on?
max temp 24/7 will be around 60-66 max (with programs/games runing) and 48-52 on idle depending on your cpu cooler
its written here : מפרט מחשב <<<
TRUE 120
anyway i asked what is the max recommended temp for 24/7 ( aizu temp lo keday lavor
Shainov is Responded you the Answer!
you can be on temp of 60-65 on Max Used 24/7
and 35-45 At Idle
You Have a good cpu cooler...so you dont need to Be A Woriedd
toda raba ;D
מתן למה לא פשוט להריץ חיפוש ?
וטמפ' לא משנה OC או קירור..היא MAX באזור ה70+-..
