Heavy Usage system for 6.5k
hello and sorry that my hebrew isn't working at the moment
lately i decided i need to replace my nearly useless machine with some new beast
in my new piece i will need the whole computer, with burner, and a Screen (prefferably 24 inch) no need for mouse or keyboard, speakers or other
i will need 8 Gigs ram, this is something im locked on since i will need to provide support and work with multiple systems at a time, also, 2 hard drives, prefferably 750Gigs each +, not 6** sizes because it will be harder to find a replacement, i plan to run a raid array, so please a MOBO that will support it and 2 identical drives.
a decent quad core processor, obviously too for the virtualization
a decent video card not bleeding edge though, for occasional games, i don't need to run anything on extreme res, but it would be nice for games to run okay.
no Toy plastic cases with wierd drawings and symbol on them please, metal neat is best for me, thanks,i would like it to be well cooled, but with a degree of quietness, no cooling that will comprimise its quietness since i will sleep in the same room with it.
my main usage will be virtualization and general usage, video editing sometimes etc usual stuffs and a bit gaming, no need extravangtic Gcard.
24 inch would be really nice, but ill live with 22 inch if it would help you put everything i requested
in the budget
thank you
Matan
Q9550 + קרור צד שלישי + 2 דיסקים קשיחים של TRA לוח תומך RAID כמובן + ספק כוח מעולה 550W של סיסוניק מארז 300 של אנטק שקט יחיסת עם זרימת אויר טובה ומסך 24"
כרטיס המסך הוא 260GTX אם המשחקים הם בכלל לא רלוונטים עבורך תוכל לרדת בכרטיס ל 4870 בגירסאת 512MB או 4850 שזולים מעט יותר
מעבדים
Intel Core 2 Quad Q9550 2.83GHz 12Mb 1333MHz Tray ¤1270
פתרונות קירור למעבד
Xigmatek HDT-S963 H.D.C CPU Cooler ¤120
לוחות אם
Gigabyte GA-EP45-DS3 P45 Chipset ¤625
מארזים
Antec Three Hundred No P/S Black Midi ATX Case ¤324
ספקי כח
SeaSonic 550W SS-550HT A.PFC 120mm Fan 2xPCI-E 6+8 6xSata 80Plus ¤429
זיכרונות
A-DATA 4GB (2x2GB) DDR2-800 CL4 Vitesta Extreme כמות 2 ¤598
כוננים קשיחים
Samsung 1TB SpinPoint F1 HD103UJ SATA II 7200rpm 32MB כמות 2 ¤996
כרטיסי מסך NVIDIA
Gainward nVidia GeForce GTX260 Golden Sample 896MB 216SP PCie ¤999
כוננים אופטיים
צורב פנימי DVD+\-RW X 22 תוצרת SAMSUNG דגם SH-S223F SATA ¤129
מסכים
מסך מחשב LCD 24" SAMSUNG דגם 2443BW ¤1370
סה"כ מחיר לכל המוצרים:¤6860
3% הנחת מזומן סה"כ לאחר הנחה:¤6654.2
המפרט הורכב באתר:
TMS&FOX We Build It, You Play It
לוח תומך RAID כמובן
אז זהו, שלא.
אם איני טועה, EP45-DS3 לא תומך ברייד, אלא GA-EP45-DS3LR (תנחש מה אומר הR בשם של הדגם....).
-ספק כח ניתן "להוריד" לדגם ה500W הוא גם יספיק מעל ומעבר.
-כדי לשפר את זרימת האויר במארז עוד יותר ולקרר קצת את הארדיסקים, ניתן להוסיף מאוורר או שניים מהדגמים הבאים-
http://www.tmsfox.co.il/ProductPopUp.aspx?ProductID=1063
http://www.tmsfox.co.il/ProductPopUp.aspx?ProductID=1994
להלן מפרט נוסף.
מעבד:
[..] INTEL CORE 2 QUAD S775 2.83GHz Q9550 : "SLB8V" - BOX ¤1214
לוח אם:
[..] GIGABYTE GA-EP45-DS3LR ¤549
מסך:
[..] SAMSUNG LCD 24" 2433BW 5ms FULL HD ¤1333
כרטיס מסך:
[..] INNO3D GTX260 SP192 CORE 896MB GDDR3 - FREEZER X2 - N26A-1SDN-H3IY - RETAIL ¤790
דיסק קשיח:
[..] SAMSUNG F1 1TB 32MB SATA2 7200 RPM : HD103UJ ¤463
כמות:2
צורב:
[..] ASUS DVDRW DRW-20B1LT LIGHT SCRIBE - SATA - RETAIL ¤146
זיכרון:
[..] CORSAIR DUAL CHANNEL 4096MB DDR2 800 (2048X2) DUAL XMS2 CL 5-5-5-18 -TWIN2X4096-6400C5 ¤296
כמות:2
מארז:
[..] ANTEC THREE HUNDRED w/o PSU ¤316
ספק כוח:
[..] SEASONIC S12II 500W BRONZE - RETAIL ¤412
קרור למעבד:
[..] SCYTHE KAMA CROSS - 3 HEAT PIPES CPU COOLER ¤150
קרור למארז:
[..] SCYTHE S-FLEX 120mm 1200rpm ¤71
שירותי מעבדה:
[..] הרכבת מחשב + בדיקת מאמץ 24 שעות + בדיקות מקיפות (מבצע לחברי הפורומים) ¤0
מחיר סופי: ¤6499
hmm... its a nice build,though, maybe i should invest in a raid controller and raid 5 with 3x750GB drives? what do you think? is it worth the speed?
yairz, i sure like your build though
would you guys wait for Nehalem based boards and DDR3 memory to get cheaper? or buy now?
raid controller isn't a cheap thing... i use one with my 4 tera hdds but it was an investment... a big one
if your going for a raid 5 a good controller is worth it even that a motherboard could do the job
do i really want a onboard piece to manage 3 hard drives in raid5? the speed increase will prolly be minimal with onboard controller
one does not use raid 5 only for speed, thats why you have raid 0... one uses raid 5 for data redundancy
and on board controller does a decent job, it did so in my tests... i used a ICH10 vs my raid controller, the controller won but the ICH10 did try hard in the fight
raid 5 adds improved performance + redundancy , its basically stripe with redundancy, which gives you space of all hard drives -1 HD, but usally you should use a controller not on MOBO from my exp
btw, can you build them in foxpc? since they're opening a shop in jerusalem soon so.
