Hebrew on winXP
I installed winXP on my new comp, and I got no hebrew, when I try to installed the hebrew its just do nothing, when there's a messege on Explorer to install hebrew pack, I do ok and nothing happen. Someone can please help me ?
Did you pick Hebrew in the "Regional and Language Options" ? (Located in the Control Panal)
That's the catch, I can't choose Hebrew!
Are you sure u choose Israel ?
Yes.
Do you mean the Internet Explorer Hebrew fonts intallation or the Right-to-Left languages in the Regional and Language Options?
If you didn't install the Right-to-Left languages in the Regional and Language Options, then all you have to do is go to the
Control Panel --> Date, Time, Language and Regional Options --> Regional and Language Options --> Languages --> Install files for complex script and right-to-left languages -->apply
Then go to Regional Options and Choose Hebrew and Israel.
Edit :
Go to the link - you can find there pictures.
Already done that, nothing happen. When I do apply the V turns off, and nothing have changed - That is my problem in conclution.
connet to the internet and ask for hebrew page , the computer should ask you to install hebrew and then you 'll choose hebrew
