פורסם 2009 במרץ 617 שנים טוב אז ככה בהתחלה הצלחתי לגרום לגימפאד לפעול במשחקים שתומכים בLIVE אבל כל דבר אחר לא פעל כולל המשחק BurnoutParadise שזה בכלל עצבן אותי וכמובן אמולטורים או יותר נכון להיום אמולטורים לנינטנדו DS בכל מקרה הגעתי לפתרון משולב קודם כל יש פה את המדריך הזה Here's a mini tutorial for installing the Xbox 360 wired controller if you're having a driver problem.I was having a small driver problem when connecting the Xbox 360 wired controller to my Vista x64 Home Premium machine. There were two instances of the controller in the Device Manager:1. Xbox 360 Controller for Windows2. Controller (XBOX 360 For Windows)I downloaded the drivers for the controller from the MS site: Download Gaming SoftwareOnce I installed the MS drivers, the device "Xbox 360 Controller for Windows" was successfully installed, but the other device "Controller (XBOX 360 For Windows)" would not install the necessary driver. Even Windows Update couldn't find the appropriate drivers for it.So if you are having this same problem, follow these steps:1. First download and install the MS drivers from the link above. Once installed, connect your Xbox 360 controller to your PC and it will install the driver for "Xbox 360 Controller for Windows" but it will not find the driver for "Controller (XBOX 360 For Windows)". It will say that it failed to install the driver for that device, but that's okay because we are going to fix that now.2. Open Device Manager (Start Orb -> right click "Computer" and select Properties -> click Device Manager on top left)3. "Controller (XBOX 360 For Windows)" should be under "Other devices". Double click on it then click on the Driver tab.4. Click on "Update Driver".5. Click "Browse my computer for driver software".6. Click "Let me pick from a list of device drivers on my computer"7. Scroll down to "Human Interface Devices". Select it and click Next.8. Leave the Manufacturer as "(Standard System Devices)" and in the Model pane, select "USBHuman Interface Device" and click Next.Windows has successfully updated your driver softwareCongrats! Now you should be able to find your Xbox 360 controller in "Game Controllers" in your Control Panel.Note:: The device that was labeled "Controller (XBOX 360 For Windows)" is under "Human Interface Devices" in your Device Manager with the name of "USB Human Interface Device". If you need to find it, double click on the "USB Human Interface Device"(s) you may have and the Location: entry will tell you which one the controller is.I have made this as simple as possible so that even the most basic computer user could follow my steps to a successful install. Hopefully this will help you as it did me.http://www.vistax64.com/gaming/153000-installing-xbox-360-wired-controller.htmlשימו לב שזה גימפאד חוטי מה שיש לי אבל אולי זה יעזור לחלק שנית ולא פחות חשוב יש את עניין העדכונים במקרה שלי הייתי חייב לעשות עדכון לחלונות ורק אז זה פעל כמו שצריך בכל מקרה אם יש לכם בעיות תפעלו לפי ההוראות בדיוק הדריבר של MS לא פועל לבד מניסיון שלי או שלפחות בחלק מהמחשבים הוא לא עובד לבד
פורסם 2009 במרץ 617 שנים גילית את הplug and play? לא הייתה לי מעולם שום בעיה לחבר את השלט של ה360 שלי למחשב, וכן המערכת שלי היא 64bit..
פורסם 2009 במרץ 617 שנים מחבר אולי במקרה שלך זה היה plug and play במקרה שלי זה היה plug דפוק את הראש בקיר איזה מאה פעם ואז תגלה שזה כן עובד במשחקים שתומכים בLIVE ואז תדפוק את הראש בקיר עוד מאה פעם בניסיון להבין למה זה לעזאזל לא עובד באף דבר אחר ורק עכשיו play ודובי זה שלך לא היו בעיות לא אומר שלאחרים לא היו -בבקשה http://www.google.co.il/search?q=xbox+360+controller++vista+64+&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:he:official&client=firefox-aולא כתבתי בעיות או משהו
