פורסם 2009 במרץ 217 שנים שלום וברכה, אני רוצה לקנות מחשב נייד עם מעבד חזק וטוב למשחקים וכמובן שיהיה כ.מסך טוב. ראיתי את שני הדגמים האלו: דל: [glow=red,2,300]V9400 Model V9400 [/glow] CPU Intel® Core2 Duo Processor T9400, 6MB L2 Cache, 2.53GHz, 1066MHz FSB Memory 4096MB (2x2048) 800MHz DDR2 Dual Channel HD 320GB 5400 rpm Display 15.4'' Widescreen WXGA with TrueLife - LED(1280x800) GPU ATI Mobility RADEON HD 3450 256 MB Optical Device DVD-RW +- With Dual Layer Technology Webcam 2.0 Mega pixel web camera Bonus Dell Travel Remote control Bonus Fingerprint Reader Biometric Sound Audio type/controller: AC97 Soft Audio Speakers Two channel high definition audio Wireless Dell Wireless 1397 (802.11 b/g) Mini Card European Bluetooth Europe Dell Bluetooth 370 Card Card Reader Secure Digital (SD) and SD/IO compliant 5-in-1 Combo Card connector - reads MS, MS Pro, SD/SDIO, MMC, CD type I/II Ports (4) USB 2.0 compliant 4-pin ports HDMI connector 15-pin VGA video connector Integrated network connector 10/100/1000 LAN (RJ45) AC adapter connector Audio jacks (1 line-in, 1-line out, 1 Mic-in) 4-pin IEEE 1394 port 54 mm ExpressCard slot Consumer IR OS Free Dos Weight 2.77 kg Battery Primary 6 cell 56W/HR LI-ION HP: [glow=red,2,300] HP Pavilion DV5-1060 Model DV5-1060 [/glow] CPU 2.26 GHz Intel Core 2 Duo Processor P8400, 3 MB Level 2 cache Memory 3072 (1 x 1024 MB + 1 x 2048 MB), Up to 8 GB HD 320 GB (5400) Display 15.4 WXGA High Definition BrightView Widescreen (1280X800) GPU NVIDIA GeForce 9200M GS, Up to 1535 MB (256 MB dedicated) Optical Device Lightscribe Super Multi DVD Writer (+/-R +/-RW) with Double Layer support Sound Altec Lansing speakers 3D Sound Blaster Pro compatible sound 16 bit integrated Wireless 802.11b/g WLAN Bluetooth Yes Card Reader 5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro, or Picture cards Ports 4 USB 2.0 1 VGA port 1 HDMI connector 1 eSata connector 1 RJ11 modem connector 1 RJ45 ethernet connector 2 headphones-out 1 mic-in 1 IEEE 1394 Fingerprint reader Integrated finger print reader Integrated Camera HP Pavilion WebCam with Integrated Microphone Remote Control HP Mobile Remote Control OS Genuine Windows Vista Home Premium Weight 2.65kg Battery 6-cell Lithium-Ion (Li-Ion) battery מה אתם אומרים? אני אשמח לשמוע הצעות נוספות תודה רבה
פורסם 2009 במרץ 217 שנים נא להכניס תקציב לכותרת.שני המחשבים האלה הם אמנם עם מעבדים חזקים, אבל כרטיסי מסך בסיסיים למדי (רק קצת מעל מובנה). יש אופציות הרבה יותר טובות למשחקים.
פורסם 2009 במרץ 417 שנים בסיסי - זה אומר לא חזק.כרטיס מסך חזק למשחקים זה 9600M GT ומעלה (ובתקציב שלך לא תמצא משהו מעבר ל-9600M GT).למשל ה-Acer 6930G:http://www.shirion-computers.com/Product.asp?Pid=ACER-Aspire-6930G&Cat2Cat1ID=34&Cat2ID=213&aff=Zap〈=HEhttp://www.ivory.co.il/product.asp?productid=2974&CatCode=או HP DV5-1179EJ שקצת חורג לך מהתקציב, אבל מגיע עם אחריות לשנתיים:http://zap.co.il/model.aspx?modelid=717381
פורסם 2009 במרץ 1017 שנים מחבר --------------------------------------------------------------------------------שלום וברכה,עד שחשבתי שאני סגור על מחשב בסוף התחרטתי, ורציתי לשאול על איזה מחשב אתם ממליצים שיהיה בסביבות ה5300 ש"ח.הדרישות:-כ.מסך יותר מבסיסי-ביצועים טובים-מהירזה הכל תודה רבה.
פורסם 2009 במרץ 1017 שנים מחבר תודה רבה, הוא נראה טוב מאוד. אני לא כ"כ מכיר את החברה הזאת מבחינת איכות חומרים ובנייה והשאלה היא אם דל לא יותר טוב ממנו מבחינת איכות הבנייה.(חבר שלי די נעול על מחשב נייד תוצרת דל).ובקשר לכ.מסך יש לי 2 שאלות:1. האם הכ.מסך שיש ל2 הדגמים שהבאתי למעלה יותר טוב מהX3100 שבא עם האינספירון 1525?2. האם הכ.מסך שיש לשני המחשבים שהבאתי בתחילת הנושא יכול להריץ משחקים כמו AOM (אסטרטגיה) בלי בעיה?
פורסם 2009 במרץ 1017 שנים לדל אין מחשב שמתאים לדרישות שציינת ולתקציב כך שזה לא רלוונטי.1. כן.2. אם אתה מתכוון ל-Age of Mythology אז בהחלט כן, זה משחק עתיק וניתן לשחק בו גם עם כרטיס מסך מובנה. אם זו רמת המשחקים בה מדובר הדרישות שלך מוגזמות, כרטיס מסך בסיסי יספיק בהחלט.
פורסם 2009 במרץ 1017 שנים כרטיס המסך חשוב מהמעבד לכל הקשור למשחקים.מספק מחשבים במחירי מזומן.Gigabyte W576V-86R4 עולה כ5150 ש"ח.Acer Aspire AS6930G - 644G50MN עולה כ4600 מעבד קצת חלש יותר אבל עם 9600GT.RD510-S.AD35E P8600 2.4GHz - Free dos של LG עולה כ5190, אבל מגיע ללא מערכת הפעלה.
פורסם 2009 במרץ 1617 שנים מחבר מבחינת איכות בנייה של מחשב וחוזק המערכת בלי קשר לכ.מסך מה עדיף?ה GIGABYTE W576V-86R4 CPU Intel® Core2 Duo Processor P8600, 3MB L2 Cache, 2.4GHz, 1066MHz FSB Memory 4GB DDR2 800MHz (Up to 8GB) HD 320GB SATA 5400 RPM Display 15.4 inches 1280x800 TFT LCD Glare Type GPU nVIDIA GeForce 9600M GS 512MB Optical Device DVD-RW Super Multi Lan Ethernet 10/100/1000 Base T on Board Audio 2 Channel HD audio, Build-in 2 Stereo Speakers 1.5W, 2 Omni-Directional Digital Microphone Wireless GIGABYTE Pro/Wireless 54Mbps Bluetooth Yes, Bluetooth V2.1 Webcam Yes(Build in 2.0MP Web Camera) Card Reader 5-in-1 Card Reader (MS/MS Pro/Ms Duo/MMC/SD/xD) Ports 2xUSB 1xE-SATA/USB Combo Port HDMI Mic-in Headphone-out RJ11 RJ45 Port Replicator Port Express Card/34 & /54 Support OS No Weight 2.66 KG אוhttp://www.gamaoffice.co.il/products/133615ועכשיו מבחינת הכ.מסך של הדל 1537 האם הוא יותר טוב מה9200GS?תודה רבה.
פורסם 2009 במרץ 1617 שנים מבחינת איכות הבניה, הייתי מעדיפה את ה-1537. מבחינת מפרט, ה-W576V חזק יותר בכל התחומים.ועכשיו מבחינת הכ.מסך של הדל 1537 האם הוא יותר טוב מה9200GS?אין הבדל משמעותי.
