Gainward GeForce3 PowerPack!!! Ti/500-128mb DDR-JUMBO-TV/OUT
קראתי את הביקורת על הכרטיס שאני עומד לקנות (עם המחשב החדש...) פה:
http://www.hardocp.com/reviews/vidcards/gainward/gf3ti200_128mb_golden/index.html
ויש לי כמה שאלות, הרוב קשורות לOC...
  • בביקורת כתוב בדגם המלא של הכרטיס גם "Golden Sample", האם הדגם שהם בחנו אותו והדגם שאני קונה (מצויין בכותרת) זהים? או שיש הבדל בינהם
    The third CD contains the actual drivers and ExpertTool software. When installing the drivers, you have four different options to choose from. You have the option of selecting "Fast VGA" driver or "WHQL VGA" driver. The fast VGA driver is driver version 21.81 and is non-WHQL certified. This is the version to use if you wish to use coolbits to overclock with. The WHQL driver is driver version 21.83. The two remaining options are to either run the card in "Safe Mode" or "Enhanced Mode". By default this card is hardwired or BIOS written to run at a speed of 200MHz core and 450MHz DDR, which is higher then the stock Ti 200 speeds of 175/400. This is called "Enhanced Mode". If you wish to go into Safe Mode, it clocks the card down to regular Ti 200 speeds. The enhanced and safe modes can be controlled via the ExpertTools software included during installation or it can be installed separately. You can also manually clock the card up or down with any third party tweaker.
  • אני מניח שלפי מה שכתוב עדיף לבחור את האופצייה של ה"Enhanced". אני רק לא בטוח, הוא פשוט עם OC בגלל שהדרייבר שינה את המהירויות שלו בביוס?
    Using Riva Tuner, I was able to push this card up to a max of 240MHz core and 510MHz DDR speed! This ever so slightly exceeds Ti 500 stock speeds by 10MHz DDR. For safety's sake, and to prolong the life of this card, I would run it at 500MHz DDR basically Ti 500 speeds. I was very happy to get it to Ti 500 speeds. At 240MHz/500MHz, I got a 3DMark2001 score of 7947 3DMarks, which is right up there with the rest of the Ti 500 cards. So basically you are buying a Ti 200 card, but you can get Ti 500 speeds out of it with 128MB of DDR, so maybe there is something to them naming it the "Ti/500" after all?
  • מה זה הRIVA TUNER הזה? אחרי שאני ידע אני ישאל עוד כמה שאלות בקשר לזה... :)
1: זה פשוט שינוי בביוס של הכרטיס מסך למהירויות יש גם תוכנות לשנות את הביוס למרות שזה לא מומלץ
2: rivatuner זו תוכנה לעשות oc שעוקפת את הדרייברים והולכת ישר לכרטיס המסך ובגלל זה היא נחשבת לאחת מתוכנות הoc הטובות ביותר לכרטיסי המסך של nvidia
מה שהתכוונתי אליו זה אם זה משנה את המהירות של הכרטיס רק ע"י שינוי הגדרות בביוס, זה עד כדי כך פשוט?
כי כמו במדריך, אפשר להגיע בקלות למהירויות של TI500 (עם הריוה טיונר והדרייבר).
פשוט מאוד........
השאלה אם תצליח להגיע למהירויות של ti500 בלי שהכרטיס יתחמם ויעשה "גליצ'ים" על המסך........
gainword ידועים בתור אוברקולקרים מעולים אז אולי זה אפשרי
את זה אפשר להבין מהביקורת...
