הודעת שגיאה
שלום
אני מקבל כול הזמן את ההודעה הזו :
Last diagnostic run time: 02/05/09 18:36:49 Network Adapter Diagnostic
Network location detection
info Using home Internet connection
info Redirecting user to support call
HTTP, HTTPS, FTP Diagnostic
HTTP, HTTPS, FTP connectivity
warn FTP (Passive): Error 12007 connecting to ftp.microsoft.com: The server name or address could not be resolved
warn FTP (Active): Error 12007 connecting to ftp.microsoft.com: The server name or address could not be resolved
info HTTP: Successfully connected to www.microsoft.com.
info HTTPS: Successfully connected to www.microsoft.com.
error Could not make an FTP connection.
האם אפשר לקבל תשובה בנושא
אם אתה יכול, תעלה תמונה של השגיאה, זה מאוד לעזור...
קבל תמיד שגיאה כאילו אני לא יכול להתחבר לאתר
אני מInternet Explorer cannot display the webpage
Most likely causes:
You are not connected to the Internet.
The website is encountering problems.
There might be a typing error in the address.
What you can try:
Diagnose Connection Problems
More information
This problem can be caused by a variety of issues, including:
Internet connectivity has been lost.
The website is temporarily unavailable.
The Domain Name Server (DNS) is not reachable.
The Domain Name Server (DNS) does not have a listing for the website's domain.
If this is an HTTPS (secure) address, click Tools, click Internet Options, click Advanced, and check to be sure the SSL and TLS protocols are enabled under the security section.
For offline users
You can still view subscribed feeds and some recently viewed webpages.
To view subscribed feeds
Click the Favorites Center button , click Feeds, and then click the feed you want to view.
To view recently visited webpages (might not work on all pages)
Click Tools , and then click Work Offline.
Click the Favorites Center button , click History, and then click the page you want to view.
לאחר הדיאגנוסטיקה:
[br]פורסם בתאריך: 6.02.2009 בשעה 01:07:24
איפה זה מופיע?
אחרי שאני עולה ומנסה להיכנס לאתר כלשהוא אני מקבל דף לבן ואז עושה דיאגנוסטיקה וזו התשובה[br]פורסם בתאריך: 6.02.2009 בשעה 01:10:10
בבקשה:
Most likely causes:
What you can try:
More informatio
אין צורך להרחיב בפרטים. יש לך בעיית תקשורת ואתה לא יכול לגלוש לאתרים בפדפדפן.
עכשיו תסביר את הבעיה בכללי כך שנוכל לעדכן כותרת לדיון שלך וגם לשים אותו בפורום הנכון אם יהיה צורך.
אין לי בעיית תקשורת מאחר ואני מצליח לגלוש עם המחשבים האחרים רק במחשב הזה אני מקבל כול הזמן דף לבן וזה לא באתר מסויים כי לפעמים זה עולה רגיל וכאשר יש קישור אז אני מקבל את ההועה הזו גם אתר הבית שלי שזה וואלה הוא מופיע בחלקו ללא תמונות
יופי, עכשיו תעדכן את הכותרת של הדיון למשהו יותר אינפורמטיבי כמו "בעייה אקראית של גלישה בדפדפן" אחרת הדיון ינעל.
תסביר את אופן החיבור שלך לאינטרנט והאם זה מרחש גם בדפדפנים אחרים.
לצערי הבעיה יותר חמורה ככול שאני בודק מסתבר שאת כול העדכונים של windows הוא לא מבצע אף על פי שהוא מראה שכן אני מחובר בנתב לADSL ואין בעייית גלישה של הדפדפנים האחרים
שלח לי ה"פ שתהיה מוכן לכבד את החוקים.
