השוואה בין שני ניידים
המפרט הראשון הוא:LG
‎Model‎ ‎RD510-K.AD24E‎
‎ CPU‎ ‎Intel® CoreTM 2 Duo Processor T5800, 2.0GHz,2MB L2 Cache,800MHz FSB‎
‎ Memory‎ ‎4GB DDR2 (800MHz,Dual Channel Support, Up to 4GB)(2slots)‎
‎ HD‎ ‎250GB (SATA) 5400rpm ‎
‎ Display‎ ‎15.4'' WXGA(1280x800) *Fine Bright Technology‎
‎ GPU‎ ‎NVIDIA® GeForce® 9300M GS (DDR2 256MB VRAM, *TurboCache Support)‎
‎ Optical Device‎ ‎SATA DVD Super Multi Dual Layer (DVD-R/RW, +R/RW, RAM)‎
‎ Wireless‎ ‎Intel® Pro/Wireless 3945BG(802.11b/g/n)‎
‎ Bluetooth‎ ‎Yes (BlueCoreTM4 v2.0+EDR)‎
‎ Webcam‎ ‎Yes (1.3 Mega Pixel)‎
‎ Card Reader‎ ‎6-in-1 (xD/SD/MMC/MMC Plus/MS/MS Pro)‎
‎ Audio‎ ‎Stereo Speakers (1.5W/ch), SRS WOW HD, SRS TruSurround HD, 24bit High Definition‎
‎ Ports‎ ‎3xUSB 2.0 (including e-SATA/USB 2.0 combo), RJ11, RJ45, VGA, HDMI, HP-out, Mic-in‎
‎ OS‎ ‎Free Dos‎
‎ Weight‎ ‎2.76 Kg (6cell & ODD) / 2.61 kg (6cell & weight saver) ‎
והשני:HP
‎Intel® Pentium Dual-Core Processor T3400(2.16GHz) 667MHz FSB ,1MB L2cache‎
‎ Memory‎ ‎2048 MB (2 x 1024 MB), Up to 8 GB‎
‎ HD‎ ‎160 GB (5400)‎
‎ Display‎ ‎15.4 WXGA High Definition BrightView Widescreen (1280 x 800)‎
‎ GPU‎ ‎NVIDIA GeForce 9200M GS, Up to 1535 MB (256 MB dedicated)‎
‎ Optical Device‎ ‎Lightscribe Super Multi DVD Writer (+/-R +/-RW) with Double Layer support‎
‎ Sound‎ ‎Altec Lansing speakers‎
‎ 3D Sound Blaster Pro compatible sound 16 bit integrated‎
‎ Wireless‎ ‎802.11b/g WLAN‎
‎ Bluetooth‎ ‎Yes‎
‎ Card Reader‎ ‎5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro, or xD
‎ Ports‎ ‎4 USB 2.0 ‎
‎ 1 VGA port ‎
‎ 1 HDMI connector ‎
‎ 1 eSata connector ‎
‎ 1 RJ45 ethernet connector ‎
‎ 2 headphones-out ‎
‎ 1 mic-in ‎
‎ 1 IEEE 1394 ‎
‎ remote control infrared port (remote optional) ‎
‎ cable docking connector‎
‎ Fingerprint reader‎ ‎Integrated finger print reader ‎
‎ Integrated Camera‎ ‎HP Pavilion WebCam with Integrated Microphone‎
‎ Remote Control‎ ‎HP Mobile Remote Control‎
‎ OS‎ ‎Genuine Windows Vista Home Premium 32-bit with Service Pack 1‎
‎ Weight‎ ‎2.65kg ‎
‎ Battery‎ ‎6-cell Lithium-Ion (Li-Ion) battery ‎
מה עדיף מהשנים?....
תקציב עד 5000 ש"ח...
מחשב לסרטים הורדות ומשחקים....לא משתגע עם משחקים
הראשון חזק
בגלל המעבד ‎Intel® CoreTM 2 Duo Processor T5800, 2.0GHz,2MB L2 Cache,800MHz FSB‎
קח אותו הוא יותר משתלם אם אתה לא משתולל את משחקים חדשים הראשון יהיה מעל ומעבר
תודה אחי.
ושאר המפרט בסדר?
יש משהו שאפשר לשפר?
תראה אתה יכול גם להתחיל להסתכן לכוון הדגמים של המעבד P8400 שיספק לך ביצועים גבוהים יותר
5000 שקל זה הרבה אני חושב שסקר שוק מקיך יותר יניב לך תוצאות טובות יותר בדוק עוד מחשבים של HP וMSI ישנו מחשב של MSI ב 5200 שמגיע עם מפרט מפלצתי
השאלה אם גם חיי הסוללה חשובים בהחלט?
רוב המחשבים המוצעים עם כרטיס מסך ומעבד חזקים
יורד משמעותית את אורך חיי הסוללה
הT5800 מצויין בדוק לגבי ה P8400 2.26~ 2.3
הכטיס מסך אכן חזק יותר מה 9200M GS
ב 5000 תוכל להביא מחשב טיפה יותר טוב מה גם שה P8400 חסחוני יותר בחשמל
סדרת P
