Looking for a decent PC - 3000-3500 NIS for gaming, HD movies, programming etc..
Hi
After becoming desperate about my current problem with my good old pc, I began to think about getting a new one as I don't have the time to hassle with trying to fix this old one.
(See this thread about my problem -
http://hwzone.co.il/community/index.php?topic=378053.0
So anyhow, if I'm going to buy a new one I will probably buy it from KSP as it's the only normal PC store in my city, and I don't have time to waste on buying it from far stores.
I'm totally uneducated about the new hardware that's out in the market, and I know I can count on you guys on suggesting the best bang for the buck.
My budget is not too high 3000-3500 and I can spend even a bit more if it's going to be worth it.
I've got a 22" monitor and I would like to play video games every once in a while. And if I'm already going to play, I would like to play on high settings on 1680X1050.
How are the Quadcore CPUs? Is there going to be a difference anytime soon between them and the Dual core CPUs?
Which video card should I be picking? 9800GT? or some ATI equivalent?
I'd love to see your advices,
and I'm sorry for the English, but I'm stuck working on a Ubuntu LiveCD OS at the moment.
Thanks! :)
Regarding the graphic card -
read here. HD4850 is the best choise.
Regarding Quad-Cores for gaming - Read here. I'd choose E8400 instead.
This will be an almost best choice for price/performance/Quality point of view:
מעבד:
INTEL CORE 2 DUO S775 3.0GHz E8400 45nm : " SLAPL" - BOX ¤893
לוח אם:
ASUS P5QL ¤479
כרטיס מסך:
PALIT PCI-EX 2.0 RADEON HD4850 512MB DDR3 DVI - RETAIL ¤795
דיסק קשיח:
WD 500GB 16MB SATA2 7200 RPM - WD5000AAKS ¤323
צורב DVD:
PIONEER DVDRW DVR-215DBK X20 - SATA - BLACK ¤113
זיכרון:
ADATA VITESTA 4096MB (2048MBX2) DDR2 800 CL5 ¤290
מארז:
ANTEC NSK4480B + 380W EARTHWATS PSU ¤455
קרור למעבד:
ARCTIC-COOLING FREEZER 7 PRO CPU COOLER FOR INTEL S775 ¤111
קרור למארז:
GLACIALTECH 90mm CASE FAN - SILENT BLADE ENTRY BEARING 19dBA - BLACK - GT9225EBDL-1 ¤28
שירותי מעבדה:
הרכבת מחשב + בדיקת מאמץ 24 שעות + בדיקות מקיפות ¤75
מחיר סופי: ¤3562
