מציאת עדכון ביוס , תומך זכרון ECC
היי חברים,
לא מצעתי עדכון ללוח שלי ,
יכולים לעזור ?
הנה הפרטים של הלקוח:
SiSoftware Sandra
Computer System
Manufacturer : MSI
Model : MS-6547
Version : 1.0
Serial Number : 00000000
Unique ID : 00000000-00000000-00000000-00000000
System Chassis
Manufacturer : Uknown Chassis Manufacture
Case Type : Desktop
Can be locked : No
Version : Version 1.00
Serial Number : 123456890
Asset Tag : 0123ABC
System Mainboard
Manufacturer : MSI
MP Support : No
Model : MS-6547
Version : 1.0
BIOS ID : 62-1015-009999-00101111-040201-SiS645
Memory Controller
Error Detection Method : 32-bit ECC
Error Correction Capability : 1-bit
Supported/Current Memory Interleave : 1-way / 1-way
Number of Memory Slots : 3
Maximum Installable Memory : 384MB
Maximum Module Size : 128MB
Supported STD/FPM/(B)EDO Speeds : 70ns, 60ns
Supported Memory Types : STD, FPM, EDO, Parity, ECC, SIMM
Supported Memory Voltages : 3.3V
Physical/BIOS Memory Banks
ROW-0 (RASL-4 RASL-11) : 256MB DIMM SDRAM single-bank
ROW-1 : Empty
ROW-2 : Empty
System Chipset
Model : Silicon Integrated Systems (SiS) SiS645 CPU to PCI Bridge
Bus(es) : ISA AGP USB SMBus/i2c
Front Side Bus Speed : 4x 100MHz (400MHz data rate)
Max FSB Speed / Max Memory Speed : 4x 133MHz / 2x 166MHz
In Order Queue Depth : 8 req(s)
Priority Master Queue Depth : 7 req(s)
Chipset Hub Interface
Type : MUTOL
Width : 16-bit
Full Duplex : No
Multiplier : 1x
Logical/Chipset Memory Banks
Bank 0 Setting : 256MB DDR-SDRAM 8-1-1-1R 6-1-1-1W 2.5-3-3CL
Refresh Rate : 7.80µs
Power Down Mode : No
Fixed Hole Present : No
Environment Monitor 1
Model : Winbond W83697HF ISA
Version : 6.00
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 34.0°C / 93.2°F
CPU Temperature : 49.5°C / 121.1°F
Cooling Device(s)
Auto Fan Speed Control : No
Chassis Fan Speed : 3096rpm
Voltage Sensor(s)
CPU Core Voltage : 1.46V
+3.3V Voltage : 3.33V
+5V Voltage : 5.00V
+12V Voltage : 12.04V
-12V Voltage : -11.71V
-5V Voltage : -5.05V
Standby Voltage : 4.87V
AGP Bus
Version : 2.00
Current Data Transfer Rate : 4x
Side Band Enabled : No
Side Band Support : Yes
Fast-Writes Enabled : No
Aperture Size : 64MB
LPC Hub Controller 1
Model : Silicon Integrated Systems (SiS) SiS85C503/5513 PCI to ISA Bridge (LPC Bridge)
ACPI PM Enabled : Yes
Random Number Generator Enabled : No
Multiplier : 1/4x
Speed : 8MHz
USB Controller 1
Model : Micro-Star International Co Ltd (MSI) SiS5597/8 Universal Serial Bus Controller
Version : 1.00
OHCI Interface : Yes
Channels : 3
Legacy Emulation Enabled : No
USB Controller 2
Version : 1.00
Channels : 3
System SMBus Controller 1
Model : SiS 5595 Internal SMBus
Expansion Slot(s)
PCI1 (1h) : PCI 32-bit 3.3V Shared PME FullLength Available (Silicon Integrated Systems (SiS) 5591/2 Virtual PCI to PCI Bridge)
PCI2 (2h) : PCI 32-bit 3.3V Shared PME FullLength Available (Silicon Integrated Systems (SiS) SiS85C503/5513 PCI to ISA Bridge (LPC Bridge))
PCI3 (3h) : PCI 32-bit 3.3V Shared PME FullLength Available
PCI4 (4h) : PCI 32-bit 3.3V Shared PME FullLength InUse
PCI5 (5h) : PCI 32-bit 3.3V Shared PME FullLength Available
AGP (6h) : AGP-4x 32-bit 3.3V Shared PME FullLength InUse
Port Connector(s)
USB - Def : SSA SCSI - Mini Centronics / DB25 pin male
Performance Tips
Warning 2533 : Disabled host controllers are present. Check BIOS settings.
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
לא היית צריך להדביק את כל המגילה
בקשר לביוס - תבדוק פה ,תגלול קצת למטה עד שתגיע ללוח שלך
http://www.station-drivers.com/page/msi.htm
לא הייתי סומך על שום דבר שרשום שם, בטח שלא לעדכן ביוס לפי זה.
על הלוח עצמו בין הסלוטים רשום דגם וגרסא, מה הם ?
יש לפחות 3 גרסאות של MSI 6547 ואי אפשר להחליף ביניהם ביוסים.
זיכרון ECC יעבוד בכל מקרה, השאלה היא האם הפונקציה של ה ECC תעבוד.
לא נראה לי שהצ'יפסט תומך ב ECC אז כנראה שלא יהיה שימוש ב ECC.
אני לא צריל שהECC יעבוד (הפונקציה)
בסה"כ שהזכרון יעבוד רגיל , זה 2*256
וזה לא עובד
עזרה ?
באתר שלהם יש רשימה של חומרה שהם בדקו על הלוח ויש ברשימה של הזיכרון גם חלק שהם ECC ככה שזו לא הבעיהץ
אולי הדגם הספציפי שלך לא תואם, או שבנוסף ל ECC הוא גם Registerd/ Buffered וזו יכולה להיות בעיה.
