עזרה-פינג מאוד גבוה
יש לי Adsl 0.5 ו-WinXPויש לי פינג מאוד גבוה, בערך 200 בשרתים ישראלים,נגיד בCS אני פרימר(Framer) ואז לאנשים קשה להרוג אותי,אבל זה גם קשה בישבילי,זה גם נורא מתריד......האם זה תלוי במרחק שלי למרכזיה?
ואם אני יחליף למת"ב(אינטרנט בכבלים) אז הפינג ישתפר?
תגיבו בבקשה...... :'(
לא קוראים לזה "פריימר" אלא לאגר (ולא בירה... ;D )
בכל אופן אתה מוריד משהו שאתה משחק???
ותעזר בזה...בכל אופן לי זה עזר קצת:
Windows XP helps itself to 20% of your bandwidth!!
Software KB
Windows XP helps itself to 20 per cent of your
bandwidth, but although this sounds like the sort of
thing that could easily fuel paranoia (what's it doing
with it?), it's more just a case of sloppy and
wasteful configuration.
The culprit is the QoS (quality of service) packet
scheduler, which is intended to preserve some
available bandwidth for important applications and in
order to maintain network performance. It does this
for the best of reasons; in a business environment you
probably don't want to have the system brought to its
knees because Dave in support is busy warezing
Emannuelle in Tibet (Would you believe it? This one
really exists. Really.). But this doesn't necessarily
apply if you're using XP at home and/or you just want
to get a big file as fast as possible.
This will help increase your bandwidth for any network
connection in Windows XP PRO.
1. Make sure your logged on as actually
"Administrator". do not log on with any account that
just has administrator privileges. To log in as an
administrator:
-click on start->logoff->logoff
-in the logon screen hold Ctrl+Alt+Del.
-in the user field type 'Administrator' <-case
sensitive.
-in the password field type the password for the
administrator (if you don't have one leave blank)
-press ok
2. Start - run - type gpedit.msc
3. Expand the "Computer configuration" branch
4. Expand the "Administrative templates" branch
5. Expand the "Network" branch
6. Highlight the "QoS Packet Scheduler" in left window
7. In right window double click the "limit reservable
bandwidth" setting
8. On setting tab check the "enabled" item
9. Where it says "Bandwidth limit %" change it to read
0-- Click apply, OK, exit gpedit.msc
10. Go to your Network connections (start->my
computer->my network connection-> view network
connections). Right click on your connection, choose
properties then under the General or the Networking
tab (where it lists your protocols) make sure QoS
packet scheduler is enabled.
11. Reboot , now you are all done.
This is more of a "counter what XP does" thing. In
other words, XP seems to want to reserve 20% of the
bandwidth for itself even with QoS disabled. So why
not use it to your advantage. To demonstrate the
problem, start up a big download from a server with an
FTP client. Try to find a server that doesn't max out
your bandwidth. In this case you want a slow to medium
speed server to demonstrate this. Let it run for a
couple of minutes to get stable. The start up another
download from the same server with another instance of
your FTP client. You will notice that the available
bandwidth is now being fought over and one of the
clients download will be very slow or both will slow
down when they should both be using the available
bandwidth. Using this "tweak" both clients will have a
fair share of the bandwidth and will not fight over
the bandwidth.
לא,אני לא מוריד כלום
