שלט אלחוטי ל-iPod
חברת TEN Technology's, מציגה את השלט האלחוטי ל-iPod. 8)
LOS ANGELES, June 12 /PRNewswire/ -- TEN Technology is proud to announce a hot new product: The TEN naviPod -- the first wireless remote control for the Apple iPod®.
naviPod is the first wireless remote for the iPod consisting of a receiver that plugs into the top of the iPod and a 5-button infrared remote control that produces the same functions as the Apple iPod wired remote.
"naviPod is really going to foster a change in the idea of stereo systems. With the naviPod and a pair of speakers, the iPod becomes a true alternative to the conventional stereo system," says John Lin, CEO and founder of TEN Technology.
naviPod was specifically designed to allow the Apple iPod user to control audio functions from across the room. Just plug in a pair of self-powered speakers, or connect to a stereo receiver/amplifier, and the iPod becomes the centerpiece of a digital entertainment system. Play/Pause, Next, Previous and Volume are all right at your fingertips.
"naviPod is all about accessing your music how and where you want it,"
said Eric Prentice, CEO of Dr. Bott LLC, "This product is innovative, elegant and intuitive. It is always a pleasure to bring a great product like naviPod to market!"
Compatibility:
naviPod is available in two models, both sporting an audio out port and chrome stand. naviPod for original iPod is compatible with all generation 1 and 2 iPods with Firewire port and includes a pass-through Firewire port for keeping the iPod charged. naviPod for 3G iPod is compatible with all iPods with the new Dock Connector.
Pricing & Availability:
naviPod for original iPod and naviPod for 3G iPod are available for pre-order from Dr. Bott and its authorized resellers along with the Apple online store. Both models of naviPod retail for $49.95US/$69.95CAN.
לדגמים ה"ישנים":
http://www.drbott.com/prod/5137-NVPO.html
לדגמים החדשים:
http://www.drbott.com/prod/db.lasso?code=5138
:ylsuper:
כל הקטע במכשיר כזה הוא הניידות שלו ולא שייתקע באיזה פינה בבית ושתשלוט עליו בעזרת שלט.
אם אתה שואל אותי זה סתם גאדג'ט נחמד ולא יותר מזה !
ממש לא,
לי ונראה לי שגם ice2k יסכים איתי, למי שה-iPod הוא ספריית המוסיקה השלמה שלו, יחסר שלט אלחוטי.
אין כמו לשבת על הספה ולהעביר שירים באייפוד במקום כל פעם לקום ולשנות שיר.
יש כזה כבר ל-Creative כבר בדגמי ה-Jukebox שלהם (30-20 ג'יגה).
יקר, אני מסכים. אבל שימושי למי שזקוק לזה. :)
Looks useless to me..
Though i got a comp on my home audio system.. maybe if i didn't, or the remote would have been cooler, like with a a touch scroll, and a video connection that shows the interface on the TV.
Then it would be cool!
צעצוע נחמד , לחדר לא חושב שהיה לי שימוש בו. בסלון זה כבר משהו אחר - קצת עוזר - אבל בכלל לא שווה את המחיר, בשביל 50 ש"ח זה היה שווה. הרעיון בכללי מוצדק כי זה לא נדיר לראות אייפוד מנגן במערכת בסלון - ומה רע בשלט בשביל זה ?!
ו... אתמול קצת יצא לי לשחק עם האייפוד החדש 15 גיגה , מה להגיד באמת עשו אותו כזה דק והעיצוב החדש עושה אותו אפילו יותר קטן וסקסי , ובכלל העיצוב הרבה יותר טוב. הכפתורים החדשים קצת מעצבנים - אבל לא נוראיים - מתרגלים. הקרדיט הגדול זה לעיצוב ולגודל הקטן יותר אפילו לי קשה להאמין עכשיו עד כמה זה קטן (ודק , יותר דק מבטרייה רגילה) ולא שוקל כלום , באמת קשה להאמין שיש שם 15 גיגה ובטרייה והכל. התאורה כמובן מדהימה והמסך יותר איכותי.
ניסיתי להכניס אותו בכיס של הגינס ומה אני יגיד , לא רק שהוא נכנס אלא הוא גם נאבד שם ומטייל שם נכנס ביחד עם הפלאפון התעודות והרשיונות וזה עדיין לא נורא. יש גם משחק שלא הופיע בשום מקום באינטרנט, זה המשחק שהיה פעם בXT שיש תותח למטה שצריך לירות על מטוסים שזורקים צנחנים שאסור שיגיעו לתותח ,משחק נורא ממכר , אני מקווה שיביאו אותו לאייפוד הישן.
זהו בקיצור - מדהים בכל מה שקשור לגודל והמשקל והעיצוב העגול יותר - זה הרבה יותר ממה שזה נראה בתמונות , אבל מעבר לכל מה שנאמר אין הרבה חדש, אבל בהחלט צעד נבון.
