BSOD ויש לי קובץ DUMP, תעזרו לי בבקשה
רק לידיעה הקובץ d347bus.sys נמצא אצלי במסלול הבא:
C:\WINDOWS\system32\drivers
הנה הפרטים לאחר אנליזה:
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: 80000003, The exception code that was not handled
Arg2: 8052a828, The address that the exception occurred at
Arg3: a629aab8, Trap Frame
Arg4: 00000000
Debugging Details:
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
MODULE_NAME: d347bus
FAULTING_MODULE: 804d7000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4128a01d
EXCEPTION_CODE: (HRESULT) 0x80000003 (2147483651) - <Unable to get error code text>
FAULTING_IP:
nt+53828
8052a828 cc int 3
TRAP_FRAME: a629aab8 -- (.trap 0xffffffffa629aab8)
ErrCode = 00000000
eax=00000001 ebx=87755a08 ecx=8052a95c edx=00000031 esi=00000000 edi=00000000
eip=8052a829 esp=a629ab2c ebp=a629ab58 iopl=0 nv up ei ng nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000286
nt+0x53829:
8052a829 c3 ret
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WRONG_SYMBOLS
BUGCHECK_STR: 0x8E
LAST_CONTROL_TRANSFER: from a964cde9 to 8052a829
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
a629ab58 a964cde9 87319e08 a629ab78 0000000c nt+0x53829
a629ab84 a965632f 87319e08 00000004 00000000 afd+0x2de9
a629abc0 a9655f64 8726f5c0 88fcf6c8 a629ac10 afd+0xc32f
a629abd0 804ef095 884454e0 877ec958 877ec958 afd+0xbf64
a629ac10 805bb459 87dca248 884454e0 001f01ff nt+0x18095
a629ac40 805badab 87dca248 0126f5a8 8a763900 nt+0xe4459
a629ac68 805bae49 e29113d0 8726f5c0 000001ac nt+0xe3dab
a629acb0 805baf81 000001ac 00000001 00000000 nt+0xe3e49
a629acc4 ba68c862 000001ac a629ad00 00000003 nt+0xe3f81
a629acec a95ffe4a 000001ac a629ad64 0167f21c d347bus+0xd862
a629ad58 8054086c 000001ac 0167f27c 7c95eb94 Sandbox+0x4e4a
a629ad64 7c95eb94 badb0d00 0167f218 00000000 nt+0x6986c
a629ad68 badb0d00 0167f218 00000000 a629adcc 0x7c95eb94
a629ad6c 0167f218 00000000 a629adcc 00000000 speedfan+0xd00
a629ad70 00000000 a629adcc 00000000 00000000 0x167f218
STACK_COMMAND: kb
FOLLOWUP_IP:
d347bus+d862
ba68c862 ?? ???
SYMBOL_STACK_INDEX: 9
SYMBOL_NAME: d347bus+d862
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: d347bus.sys
Followup: MachineOwner
0: kd> lmvm d347bus
start end module name
ba67f000 ba6a4e00 d347bus T (no symbols)
Loaded symbol image file: d347bus.sys
Image path: d347bus.sys
Image name: d347bus.sys
Timestamp: Sun Aug 22 16:31:09 2004 (4128A01D)
CheckSum: 00034FBA
ImageSize: 00025E00
Translations: 0000.04b0 0000.04e0 0409.04b0 0409.04e0
[attachment deleted by admin]
נראה שחבילת ה-Symbols שהכנסת לתוכנה לא טובה.
תוריד ותכניס את חבילת הסמלים המעודכנת: לחץ כאן.
אני לא יודע למה זה באמת רשום שהחבילה לא נכונה, הבעיה היא שהורדתי בדיוק מאיפה שאמרת ואת החבילה שמתאימה למחשב שלי ולמרות זאת, רשום שיש בעיה עם החבילה.
דבר נוסף, למרות שרשום כביכול שיש בעיה עם החבילה, נראה לי ש - WINDBG עשה את העבודה וניתן לקרוא את פרטי השגיאה ( תקן אותי אם אני טועה ) כפי שנעתקתי לכאו וגם העליתי את קובץ הדאמפ.
האם אתה מזהה את אופי הבעיה והאם יש לך המלצות איך לתקנה?
תודה.
עריכה:
אוקיי עכשיו זה בסדר, זאת הודעת השגיאה לאחר ניתוח:
Microsoft ® Windows Debugger Version 6.9.0003.113 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini092308-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: C:\WINDOWS\Symbols
Executable search path is:
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700
Debug session time: Tue Sep 23 15:42:10.243 2008 (GMT+3)
System Uptime: 1 days 18:02:09.490
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image afd.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for afd.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {80000003, 8052a828, a629aab8, 0}
*** WARNING: Unable to verify timestamp for d347bus.sys
*** ERROR: Module load completed but symbols could not be loaded for d347bus.sys
*** WARNING: Unable to verify timestamp for Sandbox.SYS
*** ERROR: Module load completed but symbols could not be loaded for Sandbox.SYS
Probably caused by : d347bus.sys ( d347bus+d862 )
0: kd> !analyze -v
happening.
Arguments:
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (HRESULT) 0x80000003 (2147483651) - לפחות אחד מהארגומנטים אינו חוקי
FAULTING_IP:
nt!`string'+e
8052a828 cc int 3
ErrCode = 00000000
nt!`string'+0xf:
8052a829 c3 ret
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x8E
PROCESS_NAME: svchost.exe
STACK_TEXT:
a629ab58 a964cde9 87319e08 a629ab78 0000000c nt!`string'+0xf
a629ab84 a965632e 87319e08 00000004 00000000 afd!AfdIssueDeviceControl+0xd6
a629abc0 a9655f64 8726f5c0 88fcf6c8 a629ac10 afd!AfdRestartConnect+0x189
a629abd0 804ef095 884454e0 877ec958 877ec958 afd!AfdAllocateMdlChain+0xe
a629ac10 805bb459 87dca248 884454e0 001f01ff nt!MiCheckControlArea+0x103
a629ac40 805badab 87dca248 0126f5a8 8a763900 nt!CmpCheckValueList+0x113
a629ac68 805bae49 e29113d0 8726f5c0 000001ac nt!MiCalculatePageCommitment+0x164
a629acb0 805baf81 000001ac 00000001 00000000 nt!NtFreeVirtualMemory+0x3d3
a629acc4 ba68c862 000001ac a629ad00 00000003 nt!MiSessionRemoveImage+0x28
a629ad64 7c95eb94 badb0d00 0167f218 00000000 nt!RtlIpv4StringToAddressExA+0x149
a629ad78 00000000 00000000 00000000 00000000 0x7c95eb94
STACK_COMMAND: kb
FOLLOWUP_IP:
d347bus+d862
ba68c862 ?? ???
FAILURE_BUCKET_ID: 0x8E_d347bus+d862
נראה שיש לך התנגשויות תוכנה כלשהן בדרייברים המותקנים במחשב.
תנסה לבצע הסרה יסודית של כל הדרייברים במחשב, ולאחר מכן תתקין את כל הדרייברים העדכניים ביותר.
*אגב, הניתוח עדיין לא תקין במאה אחוז(הוא לא מצליח לטעון כל מני קבצי מערכת מסיבה כלשהי)
אני אוריד את קבצי ה-dump ואני אנסה לנתח אותם אצלי במחשב.
אם אני אגלה משהו אחר מהניתוח שאתה נתת - תקבל עידכון.
אוקיי, אני ממתין לשמוע ממך אם מצאת משהו שונה מניתוח הבעיה שהבאתי.
בקשר לדרייברים שהצעת לי להסיר, אני שמתי לב שמוזכר דרייבר אחד ששמו d347bus.sys ואם אני לא טועה הוא שייך לתוכנה דיימון טולס שמותקנת אצלי, אבל לא מהיום אלא מזמן. מכיוון שזמן די רב לא השתמשתי בה ניסיתי עכשיו לפותחה וקיבלתי הודעת שגיאה שלא ניתן לפותחה מכיוון שרכיב ה - DTPROHLP.DLL חסר
ומומלץ לנסות להתקין את התוכנה מחדש ( מה שעדיין לא עשיתי ). בכל מקרה האם נראה לך שהדרייבר הנ"ל הוא הבעייתי? ההצעה שלך להסיר את כל הדרייברים היא סיפור מההפטרה ואני מאד מקווה שלא אצטרך לבצע אותה.
בהחלט כדאי לנסות להסיר את הדימון טולס ולראות אם זה עוזר.
הרצתי כמה חיפושים בגוגל, ועלו תוצאות די ברורות:
הקובץ הזה אכן שייך לדימון טולס, והוא מתנגש עם דרייברים אחרים במערכת(לרוב זה קורה בגירסאות הישנות יותר של התוכנה)
תסיר בצורה יסודית את התוכנה(תוודא שהקובץ הנ"ל לא נשאר לך בתיקיית מערכת במקרה)
ותעדכן מה קורה.
אם הבעיה נפתרה, אבל אתה בכל זאת מעוניין בתוכנה הזאת - תתעדכן לגירסא האחרונה.
*אגב הניתוח שעשיתי לקובץ היה זהה לשלך.
**אני מעביר את הנושא לפורום תוכנה, משום שזו לא בעיית חומרה.
