עזרה עם מפרט למשחקים עד $1000 + עוד כמה שאלות
גם אופציה טובה, שווה לשקול
OK Guys,
First of all: Thanks for all the advice and help, especially Avi952. :yelclap:
This is the MIFRAT that Im going to order in a few days. The prices are from newegg.com., so if any of you have suggestions about choosing other components, please see the prices there.
The most important question I have right now is technical AND size compatibility of the components. For example, do you think the video card would fit in the Antec 300 case (I looked for some reviews on this case, but I might be wrong)?? :s05:
ASUS 20X DVD±R DVD Burner with LightScribe Black SATA Model DRW-2014L1T - Retail
$34.99
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
$84.99
WINTEC AMPX 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model 3AXT6400C5-4096K - Retail
$55.99
ASRock P43Twins1600 LGA 775 Intel P43 ATX Intel Motherboard - Retail
$69.99
Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E8500 - Retail
$189.99
Antec Three Hundred Black ATX Mid Tower Computer Case - Retail
Antec True Power Trio TP3-650 650W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply with Three 12V Rails - Retail
$119.94
MSI N9800GTX PLUS T2D512 OC GeForce 9800 GTX+ 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
$199.99
Subtotal: $755.88
THANKS! :hi:
