Asus A7s333 מה אתם באמת מקבלים בישביל הכסף
אני מצטער על האנגלית פשוט כתבתי את ההודעה בפורום אחר ורציתי לשתף כאן את הקהילה ואולי גם לקבל עצות
"until now i was working with a nice AMD k6-2 500 mhz with redfox board
ok it had some compatibility problems with Creative RIvatnt2 but it was fixed if i used the Detenator XP drivers
few days ago i desided to buy a new motherboard and CPU
so i bought Asus A7s333 and AthlonXP 1800+ 0.13
i sat in my home i opened the asus box and took the board. assembeled the CPU into the slot put a Volcano 7+ hooked up to a case and powered it up
first the Cimos is lame because it's kinda like phinix first it didn't want to work with my HD which the HD worked on the older comp
it is WDC 8.4 5400 RPM
i flashed the BIOS did not work
i took another HD put it in and it worked
YEA OK NOW OS
i entered the WIn2000 Boot cd
he started loading up some Deviced and when it reached the part of "Starting WIndows 2000" it stucked there
i look into it and i found that the CPU is working good with the board so i took my 1600+ CPU 0.18 and put it in
so the install went good but when i came to windows i had problems running games.
when i tryed running games after a few seconds of playing the comp stuck
i tryed few drivers few AGP drivers
some settings nothing worked
the buttom like is i dont like this board.
i think it made of cheap quality not asus regularity or maybe i just have bad luck
another thing is if the 8.4 HD is hooked up the bios loads him but when it allmost finish the POST window it write "Drive Fails"
but when im booting to windows with my other HD and the Failed HD hooked up as slave windows detect him even if the bios didn't
i flashed the bios to the newest version did not work.
you probably think it's a memory issue but the think is it worked on my other mobo perfectlly"
אותו מכתב גם נשלח ל אסוס בקבל ללוח הנל
כששמים דיסק של W.D לבד הואצריך להיות בלי ג'אמפר בכלל. יכול להיות שזו הבעיה איתו.
אתה החלפת את הספק או שנשארת עם מה שהיה ב K6 ?
אם זה ספק ג'נרי בן שלוש שנים אני בכלל לא מופתע שיש בעיות.
1. ניסיתי הרבה קובינציות של גמפרים
2. זה ספק יחסית חדש 300 W ATX
בסה"כ מוזר. השתמשתי בשני לוחות של ECS עם אותו צ'יפסט והם לא נתנו ביצועים מדהימים אבל הם היו יציבים ונתנו תמורה לכסף שהם עלו.
אתה בטוח שההיטסינק יושב על המעבד כמו שצריך?
לא תאמין כמה פעמים נתקלתי בדברים כאלו...
יותר נוח לקרוא
YEA OK NOW OS
מה זה משנה על איזה צד זה רשום? העיקר שאנשים יקראו את זה ויוכלו לעזור! :bash::bash:
תאמת לקחתי את ה 1600+ מלוח ECS
הלוח ECS עבד מצויין עם האדיסק הבעיתי ועם המעבד 1800+
רק ב ASUS הוא לא עובד
BTW : ECS אחלה לוחות לא משנה מה יגידו יש לי
k7s5a
הוא פצצה אני מאד מרוצה
כן האיטסינק יושב בדיוק במקום בדיוק בצד שהוא צריך
אין בעיות חום
המחשב נתקע שהוא על 42 מעלות
אם הפעלת את ה K7S5A אז כנראה שאתה יודע מה אתה עושה, בסה"כ אותו לוח.
ניסית להחליף את האסוס? אולי הוא פשוט דפוק.
זה באמת מה שאני צריך לנסות.
למרות שהלוח חדש
אין סיבה שהוא לא יעבוד
לדעתי המודל הזה ספציפית הוא לא משהו
רק מלהסתכל על הלוח רואים שהוא לא משהו
יש לו הנדסת אנוש בגרוש
ביוס על הפנים
אחי ביוס פיניקס הוא גרוע אבל הוא לא הכי חרא שיש! ;D
אם קראת את כל מה שכתבתי היית צריך לדעת שלא ממש אכפת לי מהביוס אחרי שגיליתי כל כך הרבה תקלות עם הלוח הזה
שמחתי את כל המכתב הזה לאסוס ומה הם כותבים לי בחזרה
"תנסה להחליף כבלים של IDE"
מממממממממממממההההה הההקקקשששררר
כתבתי להם שהמעבד 1800 לא עובד שמשחקים נתקעים ולהם אכפת מכבל
פעם אחרונה שכתבתי לאסוס היה לפני שנה ואני עדיין מחכה לתשובה
לג'יגבייט לקח 3 חודשים לענות
אם הם כבר ענו לך אתה במצב טוב
הם כבר ענו לי 3 פעמיים
אבל לא לעניין
מעצנות אותי התשובות שלהם
אלה תשובות שהם ואתה יודע שהם לא יעזרו לאף אחד פשוט יש להם דף כזה שאם למישהו יש בעיה להגיד לו את הדברים הנל
