איזה מסך לקנות? CTX EX950F vs ViewSonic E95 vs Mag 996PF vs LG E900B
ראיתי עכשיו עוד כמה מסכים שקצת חורגים מהתקציב ואני לא יודע אם הם שווים את זה ואיזה מהם עדיף...
הכוונה היא ל LG F900B שעולה 1700 ש"ח.
VIEWSONIC G90F שעולה 1650
ו SAMSUNG 995DF שעולה 1600
מה דעתכם?
לי יש את מסך ה17" המקביל של LG (F700P) ואני לא רואה סיבה לרכוש מסך 19" כששני המסכים מסוגלים להגיע לאותה רזולוציה...
נו טוב, אני בכל מקרה החלטתי ללכת על ה VIEWSONIC G90F ...
Monitor: Samsung 900NF
Cost: $297
Months on list: 13
Price Change: -$25
For a little over a year now we have been recommending the Samsung 900F 19" monitor, and it doesn't look to change this month either. The Samsung monitor is one of the highest performing in its field, and comes at a reasonable price. Until we see LCD monitors that are able to outperform high-end CRTs (at a reasonable price), we're sticking with the good ole' CRT.
The Samsung 900F is one of the best monitor purchases we could make for our particular price range. The Samsung does not sacrifice any of the options that many monitors in this price range are forced to do. The 900NF has a list of very impressive features, such as a flat, aperture-grill CRT tube, a .25mm dot pitch, and up to a 76 Hz refresh rate at 1600x1200. Lower resolutions yield even higher refresh rates, and color and image quality are both top-notch.
For those of you who simply can't stand aperture-grill tubes we recommend the LG 915FT Plus, which offers a Flatron tube which offers the best of standard and aperture grill technology without the two nasty horizontal wires that cross the screen. The monitor also features high refresh rates and resolutions that are not normally supported in many shadow mask CRTs. The LG product is excellent, and can stand with the best aperture grill tubes for the price.
Please keep in mind that when buying any type or brand of monitor, there is always the chance of receiving a defective unit, so be certain to purchase only from a vendor that offers liberal return and replacement options.
קודם כל, מאיפה זה לקוח?
ושנית, כמה הוא עולה בישראל ואיפה ניתן להשיג אותו?
