מפרט לעבודה משרדית ב 3K ללא מסך, ללא אוברקלוק
הציעו לחבר את ההצעה הבאה:
MotherBoard Intel® DG35ES Eva Cove. Intel G35 Express Chipset With ICH8R. 1333/1066MHz FSB. Up to 8GB of dual channel DDR2 800/ 667 SDRAM memory. Intel® High Definition Audio support for 5.1 Surround .
Exp. Slots 1 x PCI Express x16, 2 x PCI Express x1, 1 x PCI
CPU Intel® Core2 Duo E8200. 2.66GHz 1333MHz FSB, 6MB shared L2 cache.
Memory 2GB (1GB x 2) DDR2 800 with SPD (Kingston/Samsung/Hynix)
CASE Midi Tower. Disk Drive Bays : 4x5.25inch/ 5x3.5inch. Dual USB 2.0.
Power Supply 400W. No Noice (< 18DB) 12cm FAN Special PFC technology (save 40% power usage). 4 level protection (Over voltage, over current
over loading, output short circuit)
Keyboard Logitech PS2 Keyboard
Mouse Microsoft® Mouse Optical PS2/USB
Video Card nVidia GeForce PX8600 GT TDH 512MB, 512MB GDDR2/Memory clock400MHz/Memory data rate 800MHz/Output Dual-Link DVI, Single-Link DVI, HDTV/128-bit bandwidth( GB/sec.)12.8/Fill Rate(billion texels/sec) 8.64/RAMDACs (MHz) 400 ,directx 10
Integrated Disk Controller Four Serial ATA II interfaces
DISK Serial ATA II 250GB 16MB Cache 7200 rpm (Western Digital/Seagate)
Optical Device LG Double Layer 20x SuperMulti Drive. Compatible with all DVD and CD formats. With Vista compatible software.
Integrated LAN Intel® Gigabit (100/1000 Mbits/sec) LAN subsystem Gigabit Ethernet Controller
USB 2.0 8 X USB 2.0 On Board 2 front and 6 back
FireWire 1394 OnBoard 1FireWire (IEEE 1394)
Integrated Sound Intel® High Definition 6-channel (5.1) Audio subsystem. Realtek ALC 888, 6-channel High-Definition
Audio CODEC. Support Jack-Sensing, Enumeration, Multi-streaming. A signal-to-noise (S/N) ratio of 95 dB.
Operating System Microsoft® Win XP Professional
Warranty 3 Years
(Optical device -2 Year), parts only
Total Price ¤ 2950
מה דעתכם?
יש הצעות אחרות בתקציב הזה?
זה יהיה עדיף
מעבד:
Intel Core 2 Duo E7200 2.53Ghz Penryn OEM
כמות: 1 - מחיר: ¤596
קירור למעבד:
Arctic Cooling Freezer 7 Pro
כמות: 1 - מחיר: ¤105
לוח אם:
Gigabyte GA-P31-DS3L
כמות: 1 - מחיר: ¤347
מארז:
Coolermaster Elite 340 Black
כמות: 1 - מחיר: ¤191
קירור למארז:
THERMALTAKE 120mm THUNDERBLADE GREEN LED
כמות: 1 - מחיר: ¤46
ספק כוח:
Compucase HEC ATX VER 2.0 2 fans 500TRT 24PINS
כמות: 1 - מחיר: ¤292
זיכרון:
A-Data 1GB DDR2-800 Vitesta HeatSink CL5
כמות: 2 - מחיר: ¤119
קשיח למחשב שולחני:
Western Digital 320Gb 16MB AAKS
כמות: 1 - מחיר: ¤286
כרטיס מסך:
Palit 9600GT Sonic 512MB DDR3 Retail
כמות: 1 - מחיר: ¤657
כונן אופטי:
LG H55NK DVD-RW Dual Layer X20 SuperMulti Black
כמות: 1 - מחיר: ¤122
מקלדת:
LOGITECH Deluxe 660 Cordless Desktop - OEM
כמות: 1 - מחיר: ¤165
הרכבה:
הרכבת מערכת מחשב 3000שח ומעלה כולל בדיקות
כמות: 1 - מחיר: ¤5
המהרת מערכת מחשב:
אני מעוניין בהמהרת המעבד
כמות: 1 - מחיר: ¤0
סה"כ: ¤3050
מחיר אחרי הנחת מזומן הינו : ¤2989
http://tms.co.il/preview/spec/ywcfqt3n
כמה דברים תשים לב שאם אתה משלם במזומן המחיר פחות מ3K ולכן ההרכבה תתיקר ב40 ש"ח
דבר שני אין ממש טעם לקנות מערכת הפעלה במקום זה עדיף לשפר את המערכת שאתה קונה
לקנות מערכת הפעלה זה דווקא טוב מאד. מערכת רשמית ותקנית תעבוד כמו שצריך עם ההתקנים השונים ותאפשר לך יציבות לעומת מערכת שמקורה אינו ידוע ולך תדע מה שמו לך שמה. שלא לדבר על עדכוני אבטחה וחבילות שירות (Service packs).
כמובן שזה אינו בתוקף אם תחליט לשים מערכת הפעלה חינמית (לינוקס) או שכבר יש לך מערכת ברשיון ואתה יכול להתקין אותה על המחשב החדש (ובאופן רשמי, צריך גם להסיר אותה מהמחשב הישן).
מה שכן, משתמש ביתי יכול בהחלט לחסוך 200-250 ש"ח ולקנות Win XP Home במקום Pro (אם עדיין מוכרים אותה).
אני עדיין לא מבין למה לשלם עבור מערכת הפעלה 300 ש"ח שזה 10% מהתקציב :s07:
א. כי ככה זה. בשביל מערכת צריך רשיון, או להשתמש בחינמית, שהיא אגב גם ברשיון, אלא שהוא לא עולה כסף (ואני לא נכנס פה לדיון על דורסנותה של יצרנית תוכנה זו או אחרת, שבו שנינו באותו הצד, תאמין לי).
ב. מערכת ברשיון לא תכיל כל מיני רכיבים זדוניים או לא תקינים שהוספו על ידי מי שפרץ את מערכת ההפעלה שהשגת בחינם, ואחר כך תשלם על זה ביוקר, או שסתם תקבל מסכים כחולים מדי פעם.
ג. מערכת ברשיון מזכה אותך בעדכוני אבטחה וחבילות שירות שבדרך-כלל מגינות עליך מפני מרעין בישין ותורמות ליציבותה (שוב, בלי מסכים כחולים).
ד. מערכת ברשיון מזכה אותך בתמיכה טכנית של יצרניתה (יתרון ע-צ-ו-ם שרובנו בכלל לא טורחים להשתמש בו, ומבזבזים ימים שלמים בנסיונות למצוא פתרון לבעיה שאפשר לפעמים לפתור בטלפון למחלקת התמיכה של היצרנית).
לאור כל הנ"ל - ומעבר לדרישה החוקית, שווה להקדיש 10-15% מהתקציב כדי להבטיח מחשב שיעבוד 100% מהזמן בתפוקה מלאה, בלי מסכים כחולים, סוסים טרויאנים, ושאר צרות צרורות. לחוויית השימוש במחשב זה בטח משמעותי הרבה יותר מתזמונים הדוקים יותר של הזכרונות או עוד 0.13 מגהרץ בתדר של המעבד.
תודה על ההצעות.
חובה מערכת הפעלה מכיוון שהמחשב מיועד לעבודה שלו והוא חייב מערכת חוקית.
אצלי בבית הסיפור שונה, אבל זאת הדרישה כאן.
כמו כן הבנתי ממנו שהוא זקוק לכרטיס מסך שישמש לתוכנות CAD, כלומר משהו מה quadro-ים.
אולי כדאי לפרט מה יהיו השימושים של המחשב - משרדי? סרטים בהפרדה גבוהה? שקט? (אנחנו יודעים כבר שצריך שימוש ב-CAD, אבל לא בטוח שצריך כרטיס quadro, אם מדובר סתם בשרטוט טכני למשל).
שימוש משרדי, אינטרנט ואופיס. כמו כן המחשב אמור לשמש לתוכנות CAD, כמו Solid works ו AutoCAD, אבל לא לשרטוטים מורכבים מידי.
שיהיה שקט באופן סביר, לא צריך משהו מעבר, אין צורך בקירור מים או חנקן נוזלי.
אין צורך בסרטים HD, אין צורך במשחקים. המחשב מיועד לעבודה בלבד, בתחום הנדסת מכונות.
מפרט עם כרטיס מסך נפרד ברמה מספיקה לשימושים שלך (לא צריך קוואדרו), עם חריגה של כ-300 ש"ח.
* 4 ג"ב זכרון כי זה חשוב לתוכנות שרטוט (למרות ש-XP מזהה רק 3.5 ג"ב או משהו כזה) ושווה לשים על זה עוד 200 שקל בעיני.
* מארז (כולל ספק) איכותי ואמין, להחליף את המאוורר המקורי שמגיע איתו בקירור למארז שהוספתי כדי לקבל מחשב יותר שקט.
* מערכת הפעלה Win Xp Pro
מעבד:
Intel Core 2 Duo E7200 2.53Ghz Penryn BOX
כמות: 1 - מחיר: ¤615
קירור למעבד:
Glacialtech 5060L Light 775 24dba
כמות: 1 - מחיר: ¤46
לוח אם:
מארז:
Compucase HEC 6A19 400TRT Black
כמות: 1 - מחיר: ¤362
קירור למארז:
Arctic Cooling AF12025 PWM 120mm
כמות: 1 - מחיר: ¤33
זיכרון:
G.Skill 4GB DDR2-800 DualKit (2x2GB) CL5-5-5-15 4GBPQ
כמות: 1 - מחיר: ¤433
קשיח למחשב שולחני:
כרטיס מסך:
Sapphire HD 3450 512MB DDR2 Retail
כמות: 1 - מחיר: ¤240
כונן אופטי:
LG GH20NS DVD-RW x20 Dual Layer Sata Black
כמות: 1 - מחיר: ¤128
מקלדת:
הרכבה:
כמות: 1 - מחיר: ¤5
תוכנות:
Microsoft Windows XP Professional SP2 - English Version
כמות: 1 - מחיר: ¤635
סה"כ: ¤3295
מחיר אחרי הנחת מזומן הינו : ¤3230
http://tms.co.il/preview/spec/z3s45fth
