לוח אם ל-P3 אם DDR 400MHZ?
האם הלוח הבא מתאים ל-P3?
Soyo SY-P4X400 DRAGON Ultra זה שם הלוח.
לא, זה לפנטיום 4 סוקט 478.
CPU support Socket 478-based Intel Pentium 4 processors
Form factor ATX
Chipset VIA P4X400
North bridge VIA VT8754
South bridge VIA VT8235
Interconnect V-Link (533MB/s)
PCI slots 5 32-bit/33MHz
AGP slots 2X/4X/8X AGP Pro (1.5V only)
AMR/CNR slots none
Memory 3 184-pin DIMM sockets
Maximum of 3GB of DDR333/266/200 SDRAM
Storage I/O Floppy disk
2 channels ATA/133
Serial ATA None
RAID HighPoint HPT372
2 channels ATA/133 IDE RAID 0,1,0+1
Legacy ports 1 PS/2 keyboard, 1 PS/2 mouse, Serial and Parallel ports
USB 2 USB 2.0/1.1 ports
4 additional USB 2.0/1.1 ports via 3 1/2 drive bay expansion headers
Firewire None
Audio C-Media CMI8738-MX 6-channel audio
standard audio jacks
S/PDIF input and output ports via PCI back plate expansion header
Ethernet RealTek RTL8100B 10/100 Ethernet
BIOS Phoenix - AwardBIOS
Bus speeds 100-132MHz in 1MHz increments (for 100MHz FSB CPUs)
133-165MHz in 1MHz increments (for 133MHz FSB CPUs)
Bus dividers None
Voltages CPU: 1.10-1.850 in 0.025V increments
DRAM: 2.6-2.8V in 0.1V increments
AGP: 1.6-1.8V in 0.1V increments
Monitoring Voltage, fan status, and temperature monitoring
http://www.tech-report.com/reviews/2002q4/soyo-p4x400/index.x?pg=1
:-X אופס לא שמתי לב...
אפשר לנועל...
