לבעלי HD2900 יש פיתרון לקירור זול ושקט CoolerMaster CoolViva Pro \ CoolViva Z1
Application NVIDIA GeForce
9600GT,
8800GTS 512MB (G92 Ver.),
8800GT,
8600 series, 8500 series,
7600 series, 7300 series
ATI Radeon
HD3870, HD3850,
HD2900, HD2600, HD2400,
X1950, X1900,
X1800,
X1650,
X1550
Dimensions 178.5 x 130 x 41 mm
Weight 320 g
Heat Sink Dimensions Copper base/ 3 heat pies/ Aluminum fin
Heat Sink Material 145 x 112 x 38 mm
Heat Pipes Dimensions Φ 6 mm
Fan Dimension (W / H / D) Φ 74 x 22.5 mm
Fan Speed 700~1800 ± 10% R.P.M.
Fan Airflow 7.94 CFM
Fan Air Pressure 2.272 mmH2O
Bearing Type 2 ball bearing
Fan Life Expectancy 50, 000 hours
Fan Noise Level (dB-A) 20 dBA
Connector 4 pin
Rated Voltage 12 V
Start Voltage 5 V
Operating Voltage 5~12.6 V
Rated Current 0.07~0.48 A
Input Power 0.84~2.76 W
Memory Heat Sink Dimensions 13 x 12 x 8.8 mm
Memory Heat Sink Material Aluminum
Memory Heat Sink Quantity 8 pcs
http://www.aluf.co.il/view_prod_he.aspx?ProdID=2137429356
הגרסה הבאה היא קירור פאסיבי לחלוטין
CoolViva Z1
8800GT,
ATI Radeon
HD3870, HD3850,
X1950, X1900,
X1800,
X1650,
X1650 Pro,
X1550
Weight 286.12 g
Heat Sink Material Copper base/ 2 heat pipes/ Aluminum
Heat Sink Dimensions 173 x 122.3 x 55.41 mm
Heat Pipes Dimensions Φ6 mm
Note Fan is optional component
http://www.aluf.co.il/view_prod_he.aspx?ProdID=2137429358
