לא מצליח לצרוב DL בנירו + לוג ותמונה
אניח מנסה לצרוב UDF
קובצ של 7 גיגה ולא מצליח
*יכול להיות שבגלל שאני צורב מ HDD שנמצא על אותו IDE שהצורב נמצא ?*
לוג :
Windows User
Windows Vista 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.3.2.1
Internal Version: 8, 3, 2, 1
Recorder: <_NEC DVD_RW ND-3520AW> Version: 3.07 - HA 1 TA 0 - 8.3.2.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <AG0146Q MKK480T >Version: 1.01 - HA 1 TA 1 - 8.3.2.1
=== Scsi-Device-Map ===
CdRomPeripheral : AG0146Q MKK480T 1.01 ax832gqn Port 6 ID 0 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-3520AW F: CdRom0
AG0146Q MKK480T D: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2045MB (2094860kB)
Free physical memory: 1195MB (1224260kB)
Memory in use : 41 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
6.5.2008
UDF compilation
20:04:43 PM #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
20:04:43 PM #2 Text 0 File Isodoc.cpp, Line 6713
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
20:04:43 PM #3 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using DVD media
20:04:43 PM #4 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
20:04:43 PM #5 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 3886079 (863:34.29, 7589MB)
20:04:43 PM #6 Text 0 File DlgWaitCD.cpp, Line 323
Write in overburning mode: NO (enabled: CD)
20:04:43 PM #7 Text 0 File DlgWaitCD.cpp, Line 2932
Recorder: _NEC DVD_RW ND-3520AW, Media type: DVD+R DL
20:04:43 PM #8 Text 0 File DlgWaitCD.cpp, Line 497
>>> Protocol of DlgWaitCD activities: <<<
20:04:43 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 754
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 3886080 (3886080) = #3886080/863:34.30
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3886080 blocks [F: _NEC DVD_RW ND-3520AW]
20:04:43 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 956
Prepare [F: _NEC DVD_RW ND-3520AW] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 7958691840, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 3886080 | 0 | 0x00
3886080 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
20:05:03 PM #11 Text 0 File SCSIPTICommands.cpp, Line 264
Error on LockVolume: Access is denied.
20:05:03 PM #12 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
20:05:03 PM #13 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
20:05:03 PM #14 Text 0 File Burncd.cpp, Line 4359
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
20:05:03 PM #15 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
20:05:03 PM #16 Text 0 File Burncd.cpp, Line 4481
Cache writing successful.
20:05:03 PM #17 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
20:05:03 PM #18 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 2.4x (3,324 KB/s)
20:05:03 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
20:05:03 PM #20 Text 0 File DVDPlusDualLayer.cpp, Line 756
L0 Data Zone Capacity not set.
Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
20:05:03 PM #21 CDR -1205 File DVDPlusDualLayer.cpp, Line 772
Burning Layer 1
20:05:03 PM #22 Text 0 File DVDPlusDualLayer.cpp, Line 782
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
20:05:03 PM #23 SPTI -1066 File SCSIPassThrough.cpp, Line 196
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAD 00 00 00 00 00 00 00 08 04 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24 00 00 C0 00 07
Buffer x07aa2b40: Len x804
20:05:03 PM #24 Text 0 File DVDR.cpp, Line 6901
Drive: _NEC DVD_RW ND-3520AW
Book Type request [NEC]: DVD-ROM, write to RAM
select Book Type setting from RAM
Changing the Book Type was finished successfully, return code 0
20:05:03 PM #25 CDR -1207 File DVDR.cpp, Line 6605
Book Type automatically set to: DVD-ROM
20:05:03 PM #26 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: No
20:05:03 PM #27 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
20:06:15 PM #28 SPTI -1093 File SCSIPassThrough.cpp, Line 196
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1093)
CDB Data: 0x2A 00 00 00 75 60 00 00 20 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0x00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 02
Buffer x0d6ceb00: Len x10000
0xA7 96 B1 28 D1 60 50 01 C6 13 14 03 35 C3 2B B0
0xF3 48 26 71 CD F2 77 D0 32 7F 76 E3 87 D4 53 3A
0x2E 3F 7A 6D C1 6A 25 4E 64 8F 44 C8 03 FC F3 6D
20:06:15 PM #29 CDR -1093 File Writer.cpp, Line 306
No seek complete
20:06:15 PM #30 SPTI -1135 File SCSIPassThrough.cpp, Line 196
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
CDB Data: 0x5B 01 01 00 00 01 00 00 00 00 00 00
Sense Code: 0x0C
Sense Qual: 0x00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
20:06:15 PM #31 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 30048
20:06:15 PM #32 Text 0 File DVDR.cpp, Line 6901
20:06:15 PM #33 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 2.4x (3,324 KB/s)
20:06:15 PM #34 Text 0 File SCSIPTICommands.cpp, Line 287
20:06:18 PM #35 Text 0 File Cdrdrv.cpp, Line 11420
DriveLocker: UnLockVolume completed
20:06:18 PM #36 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
[attachment deleted by admin]
אתה מצליח לצרוב דיסקים רגילים?
על איזה מדיה אתה צורב?
תנסה לצרוב על מהירות 4x ותראה אם עדיין קיימת הבעייה.
כן אין בעייה לצרוב דיסקים רגילים CD או DVD רגילים
אני צורב על דיסק HP DL 2.4X
הצורב של NEC 3520AW
ה FIRMWARE שידרגתי ל 3.07
