רק 32 ב 3DMARK03 ב1280X960
מה לעשות??
יש לי P4 2GHZ זכרונות 256MB DDR PC2100 זה מה שכתוב על הכרטיס הגרפי שלי:
Intel® 82845G/GL Graphics Controller Driver 6.13.1.3119
Description Intel® 82845G/GL Graphics Controller
Manufacturer Intel Corporation
Total Local Video Memory 16 MB
Total Local Texture Memory 4.00 GB
Total AGP Memory 48 MB
Driver File ialmrnt5.dll
Driver Version 6.13.1.3119
Driver Date 5-22-2002
Driver WHQL Certified false
Max Texture Width 2048 px
Max Texture Height 2048 px
Max User Clipping Planes 0
Max Active Hardware Lights 0
Max Texture Blending Stages 4
Textures In Single Pass 4
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
VGA Memory Clock 0.0 Hz
VGA Core Clock 0.0 Hz
PCI
Name Intel® 82845G/GL Graphics Controller
Vendor ID 0x8086
Device ID 0x2562
SubSystem ID 0x52478086
Revision ID 0x01
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [uYVY]
FourCC [YUY2]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
Subpixel Accurate Rasterizing, Stencil Buffers, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Point Primitive Support, DXT Compressed Textures, Mipmapped Cube Textures, Texture Border Color
ועל הלוח אם:
Model D845GBV
Version AAA84540-301
BIOS Properties
AGP
Revision 2.0
Rate 1x, 2x, 4x
Available Rate 0x00000007
Selected Rate 0x00000000
Aperture Size 64 MB
Sideband Addressing supported (disabled)
Fast Write supported (disabled)
המממ ... הכרטיס שלך לא ממש נועד לזה שיריצו עליו דברים יותר גראפיים מסוליטר
חחח...סליחה , אבל אני מאמין שהתשובה נכונה .
יש לך הכל...רק כרטיס גרפי אתה צריך להחליף והתוצאה שלך תקפוץ הופה הופה הופה היי למעלה..:)
חהחה...אהבתי... :)
ועכשיו ברצינות , לפותח הת'רד , יש לך כרטיס מסך אונבורד , למה אתה מצפה ב-3DMARK2003 ועוד ברזולצייה כזו ?!
אחי , תחליף כרטיס מסך .
-----החלטתם כבר על כרטיס מסך טוב וזול שיריץ UT2003 וMOHAA בלי בעיה??
עריכה: אני יפרמט גם את המחשב הנוכחי וזה עדיין נראה לי תוצאה נמוכה. גם שמתי לב שה3DMARK רושם שאין לי תמיכה בכמעט אף מבחן.
http://planet.nana.co.il/jw666/3dmark%2EJPG
איך מכניסים לעזאזל קישורים ותמונות ותודה לכולם
שיכלול R9700 שיעבור OC רצחני
WHAT THE FUCK ? אתה רוצה לעשות OC ל-9700 ?
האמת לא כ"כ הבנתי מה אתה רוצה אבל אם הבנתי נכון אז הכרטיס שהייתי ממליץ לך לקנות למחשב המוזכר בת'רד הוא GF4 MX 440 . זול וטוב.
מה MX440 ?! מינימום ראדון 9100 !
חחח
אני נעלץ להסכים, קנה כרטיס מסך חדש וטוב!
1. בטח שהכרטיס שלך לא תומך בכלום , הוא ענתיקה.
2. ל-or007 , הוא רצה משהו זול וטוב , MX 440 יספיק בהחלט.
MX440 זה הכרטיס האחרון שהייתי ממליץ לך.
פשוט כך , האחרון !
אם אתה מדבר על זול ברמה כזאת קח רדאון !
או 9000 פרו או 9100 , תלוי בתקציב שלך.
אל תקח , שוב - אל תקח MX440 , תסלחו לי אנשים אבל לדעתי זה פשוט חרא של כרטיס !!!
לא שהרדאונים האלו מצטיינים , אבל הם בערך מכפילים את ה-MX440 (לפחות ה-9000 פרו - אז מה עם ה-9100...?)
מכפילים ? מאיפה הבאת את זה ? תפסיק לקשקש.
לפי דעתי עדיף ך' לקחת radeon 9100 או אים אתה רוצה כרטיס שיחזיק הרבה זמן
קח radeon 9500 Pro והתוצאה ממש תזנק ;D
תגידו משהו , לא הבנתם מה הוא כתב או מה ? הוא רצה כרטיס זול , הוא לא רוצה לבזבז 1200 שקל או 600-700 שקל על כרטיס , אז תפסיקו. אם הוא היה רוצה לבזבז 1200 או 700 שקל הוא היה מציין זאת.
בדיוק! כרטיס זול וטוב זה כרטיס MX!
