שאלה לגבי לוח אם: ASUS A7N8X DELUXE
מה דעתכם על המפרט שלו (שימו לב דגם דלוקס)?
Chipset
North Bridge: NVIDIA® nForce2 SPP
South Bridge: NVIDIA® nForce2 MCP-T(Deluxe Model) / MCP
FSB
333 / 266 / 200 MHz
Memory
Dual-Channel DDR 400
3 x 184-pin DIMM Sockets
Max. 3 GB unbuffered PC3200/PC2700/PC2100/PC1600 non-ECC DDR RAM Memory (Twinbank)
Memory QVL TABLE
Expansion Slots
1 x AGP Pro/8X (1.5V only)
5 x PCI
IDE Ports
2 x UltraDMA 133/100/66/33
Serial ATA (Deluxe Model)
Silicon Image® Sil 3112A Controller with 2 ports
Support RAID 0/1
Audio
Realtek® ALC650 6CH w/built in HP amplifier
Integrated APU (Audio Processor Unit, Deluxe Model)
SoundStorm / Dolby® Digital (AC-3) Encoder (Deluxe Model)
LAN
2 Ports
MCP integrated NVIDIA® MAC + Realtek® 8201BL PHY
MCP integrated 3Com® MAC + Broadcom® AC101L PHY (Deluxe Model)
1394
2 Ports MCP-T Integrated IEEE 1394a + Realtek® PHY 8801B (Deluxe Model)
Special Features
Post Reporter (Deluxe Model)
Power Loss Restart
Q-Fan Technology
STR (Suspend-to-RAM)
C.O.P. (CPU Overheating Protection)
CPU Throttle
Back Panel I/O Ports
1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Audio I/O
4 x USB 2.0
1 x Surround L/R audio jack + 1 x CNTR/LFE audio jack (optional)
2 X RJ45 (optional, 2nd RJ45 is for Deluxe Model)
Internal I/O Connectors
2 x USB 2.0 connector support additional 2 USB 2.0 ports
CPU/Power/Chassis FAN connectors
Game Connector
20 pin ATX power connector
IDE LED connector, power LED connector
2 x 1394 Connector (Deluxe Model)
2 x SATA (Serial ATA) Connector (Deluxe Model)
WOR, WOL, Chassis Intrusion, SM Bus, SIR
Headphone (optional)
Front MIC
CD/AUX/Modem audio in
Front Panel Audio connector (optional)
BIOS Feature
4Mb Flash ROM, Award BIOS, TCAV, PnP, DMI2.0, DMI, Green
Industrial Standard
PCI 2.2, USB 2.0
Manageability
DMI 2.0, WOR, WOL, Chassis Intrusion, SM Bus
Support CD
Drivers
ASUS® PC Probe
Trend Micro PC-cillin 2002 anti-virus software with Windows® XP support
ASUS LiveUpdate Utility
Accessories
I/O Shield
SATA Cable (Deluxe Model)
2-port USB 2.0(Deluxe Model) / Game port bracket
User's Manual / Quick Reference Guide
UltraDMA 133 cable
2-Port 1394 Bracket (Deluxe Model)
FDD cable
UltraDMA 133/100/66 cable
9-pin COM cable
InterVideo® WinCinema (WinDVD/WinRip/WinCoder/WinProducer) software (Deluxe Model)
Form Factor
ATX Form Factor
12" x 9.6" (30.5cm x 24.5cm)
לעזאזל, כל זה לוח אם?!?!?!?!?!?!?!?!?!
יש לי אותו, כפי שנאמר- צפו פגיעה :)
הוא מתאים לAMD?
אם כן אז כמה הוא עולה היום?
מה זה מתאים לAMD? הוא מתוכנן לamd......
מבוסס nforce2, בארץ עולה כרגע בסביבות ה1000
מתאים ל-AMD וניתן למצוא אותו ב-900 ש"ח +/-.
יקר מידי לא? (שאלה רצנית)
יקר יחסית.
אבל אתה מקבל עליו שני כרטיסי רשת (שזה כבר 100 שקל תוספת אם אין לך)
כרטיס קול ברמה מעולה, בקר SATA, חיבורי firewire, חיבורי USB2 ומדבקשה של אסוס! :P
מה פירוש צפו פגיעה?
ואם אני לא צריך כרטיס רשת בכלל?
ואין לי מושג מה זה בקר SATA, חיבורי firewire, אז מה אתם ממליצים לי לקחת לאיי אמ די?
יש לי כרגע את ה EPOX RGA (שכולל Gforce O.B)
הבעיה היא שלכרטיס מסך אין זיכרון משלו אלא הוא משתמש בזיכרון הרגיל...
ומה גם שאין לו TV OUT,
מיכוון שאין לי כוונה לבצע OC, אני חושב להלחיף אותו (הלוח של EPOX חדש ואני יכול עדיין להחליף בחנות ולקבל זיכוי של 95%)
ולקחת את האסוס, שכולל תמיכה ב S.ATA וזה יהיה שימושי בעתיד, והלוח נותן לי את כל האפשרויות של ה EPOX,
ולרכוש בנפרד כרטיס מסך פשוט GFORCE4 מוחלש ב 288ש"ח (PROLINK) , במילא אני לא מתכנן לחרוש במשחקים על התצורה הזאת.
מה דעתכם?
התלבטתי איזה לוח אם לרכוש עם ציפסט של NFORCE2, ונראה לי שזה הלוח היחיד עם התמיכה ב S.ATA .
תוותר, לא שווה לך.
לא מתכוון לשחק? פשוט תוריד את הכמות זיכרון שהכרטיס מסך לוקח (בביוס עושים את זה)
מחשבים לא קונים לעתיד, קונים לעכשיו, שתצטרך SATA- תקנה בקר חיצוני.
לא תשתלם לך ההחלפה הזו. אתה בסופו של דבר תוציא עוד כ-300 ש"ח על ביצועים כמעט זהים. לא כדאי :nono:
לכאורה נכון אבל:
א. המהירות של בקרי S.ATA תהיה מוגבלת למהירות סלוט ה PCI...
ב. אני רוצה TV.OUT ובכל מקרה אצטרך לרכוש כ.מסך עם TV.OUT, ואני חושש שעשויות להיות התנגשויות בין הכרטיס מסך O.B ל"רגיל"
1. שתראה לי הרד דיסק שמגיע ל133 מגה בשניה אני אקנה לך את הבקר בעצמי (לא כולל סקזי)
2. תקנה ופשוט תבטל את הכרטיס בביוס, לא יהיו שום התנגשויות.
