בעיה בC# בdirectX
אהלן כולם,
הורדתי כמה דוגמאות של קודים שקשורים לDIRECTX וכשאני מנסה להריץ אותם יש לי כמה שגיאות
קוד לדוגמא:
using System;
using System.Drawing;
using System.Collections;
using System.ComponentModel;
using System.Windows.Forms;
using System.Data;
using Microsoft.DirectX;
using Microsoft.DirectX.Direct3D;
namespace Chapter1Code
/// <summary>
/// Summary description for Form1.
/// </summary>
public class Form1 : System.Windows.Forms.Form
private Device device = null;
/// <summary>
/// Required designer variable.
/// </summary>
private System.ComponentModel.Container components = null;
private float angle = 0.0f;
public Form1()
// Required for Windows Form Designer support
InitializeComponent();
this.Size = new Size(800, 600);
this.SetStyle(ControlStyles.AllPaintingInWmPaint | ControlStyles.Opaque, true);
/// <summary>
/// We will initialize our graphics device here
/// </summary>
public void InitializeGraphics()
// Set our presentation parameters
PresentParameters presentParams = new PresentParameters();
presentParams.Windowed = true;
presentParams.SwapEffect = SwapEffect.Discard;
// Create our device
device = new Device(0, DeviceType.Hardware, this, CreateFlags.SoftwareVertexProcessing, presentParams);
private void SetupCamera()
device.RenderState.CullMode = Cull.None;
device.Transform.World = Matrix.RotationAxis(new Vector3(angle / ((float)Math.PI * 2.0f), angle / ((float)Math.PI * 4.0f), angle / ((float)Math.PI * 6.0f)), angle / (float)Math.PI);
angle += 0.1f;
device.Transform.Projection = Matrix.PerspectiveFovLH((float)Math.PI / 4, this.Width / this.Height, 1.0f, 100.0f);
device.Transform.View = Matrix.LookAtLH(new Vector3(0,0, 5.0f), new Vector3(), new Vector3(0,1,0));
device.RenderState.Lighting = true;
protected override void OnPaint(System.Windows.Forms.PaintEventArgs e)
device.Clear(ClearFlags.Target, System.Drawing.Color.CornflowerBlue, 1.0f, 0);
SetupCamera();
CustomVertex.PositionNormalColored[] verts = new CustomVertex.PositionNormalColored[3];
verts[0].X = 0.0f;
verts[0].Y = 0.0f;
verts[0].Z = 1.0f;
verts[0].Normal = new Vector3(0.0f, 0.0f, -1.0f);
verts[0].Color = System.Drawing.Color.White.ToArgb();
verts[1].Position = new Vector3(-1.0f, -1.0f, 1.0f);
verts[1].Normal = new Vector3(0.0f, 0.0f, -1.0f);
verts[1].Color = System.Drawing.Color.White.ToArgb();
verts[2].Position = new Vector3(1.0f, -1.0f, 1.0f);
verts[2].Normal = new Vector3(0.0f, 0.0f, -1.0f);
verts[2].Color = System.Drawing.Color.White.ToArgb();
device.Lights[0].Type = LightType.Directional;
device.Lights[0].Position = new Vector3();
device.Lights[0].Diffuse = System.Drawing.Color.White;
device.Lights[0].Attenuation0 = 0.2f;
device.Lights[0].Range = 10000.0f;
//device.Lights[0].Commit();
device.Lights[0].Enabled = true;
device.BeginScene();
device.VertexFormat = CustomVertex.PositionNormalColored.Format;
device.DrawUserPrimitives(PrimitiveType.TriangleList, 1, verts);
device.EndScene();
device.Present();
this.Invalidate();
/// <summary>
/// Clean up any resources being used.
/// </summary>
protected override void Dispose( bool disposing )
if( disposing )
if (components != null)
components.Dispose();
base.Dispose( disposing );
#region Windows Form Designer generated code
/// <summary>
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
/// </summary>
private void InitializeComponent()
this.components = new System.ComponentModel.Container();
this.Size = new System.Drawing.Size(300,300);
this.Text = "Form1";
#endregion
/// <summary>
/// The main entry point for the application.
/// </summary>
static void Main()
using (Form1 frm = new Form1())
// Show our form and initialize our graphics engine
frm.Show();
frm.InitializeGraphics();
Application.Run(frm);
ואלה השגיאות:
Error	3	The type or namespace name 'DirectX' does not exist in the namespace 'Microsoft' (are you missing an assembly reference?)	D:\הורדות\טקסטים ושונות\C# Code\Chapter 1\Lights\Form1.cs	7	17	Lights
Error	4	The type or namespace name 'DirectX' does not exist in the namespace 'Microsoft' (are you missing an assembly reference?)	D:\הורדות\טקסטים ושונות\C# Code\Chapter 1\Lights\Form1.cs	8	17	Lights
Error	5	The type or namespace name 'Device' could not be found (are you missing a using directive or an assembly reference?)	D:\הורדות\טקסטים ושונות\C# Code\Chapter 1\Lights\Form1.cs	17	17	Lights
מה עושים?
תודה=]
א.שיניתי
ב. אני מקווה שזה יעזור
תודה=]
תתקין את הSDK האחרון(ספטמבר או אוגוסט 07, אני לא זוכר בידיוק).
תוסיף REFERENCE בתוך הפרוייקט עצמו לMicrosoft.DirectX ול Microsoft.DirectX.Direct3D.
תודה:)
