OC ל AMD 1.8 2800+
זה מתוך everst
Field Value
CPU Properties
CPU Type AMD Athlon 64 2800+
CPU Alias Newcastle S754
CPU Stepping DH-CG
CPUID CPU Name AMD Athlon 64 Processor 2800+
CPUID Revision 00000FC0h
CPU Speed
CPU Clock 1808.36 MHz
CPU Multiplier 9.0x
CPU FSB 200.93 MHz (original: 200 MHz)
Memory Bus 200.93 MHz
CPU Cache
L1 Code Cache 64 KB (Parity)
L1 Data Cache 64 KB (ECC)
L2 Cache 512 KB (On-Die, ECC, Full-Speed)
Motherboard Properties
Motherboard ID 12/21/2004-nForce-6A61CG0HC-00
Motherboard Name Gigabyte GA-K8NS (5 PCI, 1 AGP, 3 DDR DIMM, Audio, LAN)
Chipset Properties
Motherboard Chipset nVIDIA nForce3 250, AMD Hammer
Memory Timings 3-4-4-8 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
SPD Memory Modules
DIMM1 256 MB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz)
DIMM2 256 MB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz)
BIOS Properties
System BIOS Date 12/21/04
Video BIOS Date 04/13/04
Award BIOS Type Award Modular BIOS v6.00PG
Award BIOS Message GA-K8NS F10
DMI BIOS Version F10
Graphics Processor Properties
Video Adapter nVIDIA GeForce FX 5200
GPU Code Name NV34 (AGP 8x 10DE / 0322, Rev A1)
GPU Clock 250 MHz
Memory Clock 133 MHz
עכשיו העם אפשר לעשות OC למעבד ?
הוא במצב רגיל על 40 מעלות ...
