KASPERSKY ONLINE SCANNER מצא 2 וירוסים NOD32 לא מצא כלום
בסריקה ב-NOD32 לא נמצאו וירוסים
עשיתי סריקה ב-KASPERSKY ONLINE SCANNER
הנה ה-REPORT
Scan Settings
Scan using the following antivirus database extended
Scan Archives true
Scan Mail Bases true
Scan Target Critical Areas
C:\WINDOWS
C:\DOCUME~1\User\LOCALS~1\Temp\
Scan Statistics
Total number of scanned objects 16518
Number of viruses found 2
Number of infected objects 5
Number of suspicious objects 0
Duration of the scan process 00:21:51
Infected Object Name Virus Name Last Action
C:\WINDOWS\CSC\00000001 Object is locked skipped
C:\WINDOWS\Debug\PASSWD.LOG Object is locked skipped
C:\WINDOWS\SchedLgU.Txt Object is locked skipped
C:\WINDOWS\SoftwareDistribution\ReportingEvents.log Object is locked skipped
C:\WINDOWS\Sti_Trace.log Object is locked skipped
C:\WINDOWS\system32\CatRoot2\edb.log Object is locked skipped
C:\WINDOWS\system32\CatRoot2\tmp.edb Object is locked skipped
C:\WINDOWS\system32\closeapp.exe Infected: not-a-virus:RiskTool.Win32.CloseApp.a skipped
C:\WINDOWS\system32\config\ACEEvent.evt Object is locked skipped
C:\WINDOWS\system32\config\AppEvent.Evt Object is locked skipped
C:\WINDOWS\system32\config\default Object is locked skipped
C:\WINDOWS\system32\config\default.LOG Object is locked skipped
C:\WINDOWS\system32\config\SAM Object is locked skipped
C:\WINDOWS\system32\config\SAM.LOG Object is locked skipped
C:\WINDOWS\system32\config\SecEvent.Evt Object is locked skipped
C:\WINDOWS\system32\config\SECURITY Object is locked skipped
C:\WINDOWS\system32\config\SECURITY.LOG Object is locked skipped
C:\WINDOWS\system32\config\software Object is locked skipped
C:\WINDOWS\system32\config\software.LOG Object is locked skipped
C:\WINDOWS\system32\config\SysEvent.Evt Object is locked skipped
C:\WINDOWS\system32\config\system Object is locked skipped
C:\WINDOWS\system32\config\system.LOG Object is locked skipped
C:\WINDOWS\system32\drivers\sptd.sys Object is locked skipped
C:\WINDOWS\system32\h323log.txt Object is locked skipped
C:\WINDOWS\system32\vimc.exe/WISE0005.BIN Infected: not-a-virus:RiskTool.Win32.CloseApp.a skipped
C:\WINDOWS\system32\vimc.exe WiseSFX: infected - 1 skipped
C:\WINDOWS\system32\wbem\Repository\FS\INDEX.BTR Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\INDEX.MAP Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\MAPPING.VER Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\MAPPING1.MAP Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\MAPPING2.MAP Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\OBJECTS.DATA Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\OBJECTS.MAP Object is locked skipped
C:\WINDOWS\wiadebug.log Object is locked skipped
C:\WINDOWS\wiaservc.log Object is locked skipped
C:\WINDOWS\WindowsUpdate.log Object is locked skipped
C:\DOCUME~1\User\LOCALS~1\Temp\3F34.tmp/data0005 Infected: not-a-virus:AdWare.Win32.BHO.dh skipped
C:\DOCUME~1\User\LOCALS~1\Temp\3F34.tmp NSIS: infected - 1 skipped
Scan process completed.
מה חדש?
זה עובד גם להפך
NOD מוצא דברים שKAV לא
זה פשוט שתי תוכנות שונות עם מאגרים שונים. אפשר לצפות את זה שיהיו אי תאימויות בתוצאות שלהם
אז לא צריך לדאוג ?
מה חדש?
זה עובד גם להפך
כמו שתמיד אמרתי...קונספירציה של חברות האנטי וירוס,אני בטוח שעכשיו גם אם תבדוק עם נורטון גם תמצא :lol:
הגזמת נורטון לא ימצא גם אם תבדוק איתו ראשון ;) אבל אולי ANTIVIR ו AVG החינמים ימצאו משהו ש KAV ו NOD פספסו :smile1:
אם הפרמטרים של msconfig , tasks manager תקינים , אין לייחס חשיבות רבה לסריקת וירוסים.
