מחפש דריור של מקלדת שליטה!
חברה אני חייב את הדריור של המקלדת שליטה הזו אני כבר מיואש..
REVEL-mkb02
תודה לעוזרים...:)
קבל:
This keyboard is a standard MIDI keyboard that requires no drivers at all. Not even in Windows 3. The CD or Floppy disks supplied are only application software. This keyboard will work with any MIDI application software and the software will work with any MIDI keyboard given the appropriate cable for your sound card.
Now to work
The difficulty is getting the game port on the computer set up and talking to Windows as a MIDI port.
Follow the instructions below.
1. In 'Device Manager' (DM), look in 'Sound, Video and Game Controllers' (SVGC).
2. Ensure that 'MPU-401 Compatible MIDI Device' is listed.
3. If it is not install it as follows:
3.1 START, SETTINGS, CONTROL PANNEL, ADD NEW HARDWARE.
3.2 Choose to 'Select from list'.
3.3 Select 'Microsoft'
3.4 Select 'MPU-401 Compatible MIDI Device'
3.5 Follow the on screen prompts to install the driver.
4. Follow steps 1, 2, 3 above and confirm that there are no conflicts with this device. Your sound card may have come with its own equivalent device but this Microsoft one should work.
5. START, SETTINGS, CONTROL PANNEL and double click 'Multimedia' or 'Sound and Multimedia'.
6. Select the MIDI tab or Devices tab.
7. Double click the 'MIDI DEVICES AND INSTRUMENTS' (not the + in a box)
8. Click 'Properties' - 'add new instrument'
9. Select MPU-401 - Select 'General MIDI Instrument'
10. Follow the prompts to install it and any others such as 'Percussion on Channel 16"
Provided the sound card is set up correctly and can play MIDI files (MID or RMI) all should work. After all the rebooting my one worked fine.
IMPORTANT NOTES FOR OLD ISA SOUND CARDS LIKE MY ONE.
The midi port IRQ and address configuration may need to be setup using a DOS configuration program or some commands entered into the AUTOEXEC.BAT file located in the root directory. Check your sound card configuration.
Ensure that the IRQ and ADDRESS'S are set to the same values in the Device Manager under 'Sound, Video and Game Controllers' - 'MPU-401 Compatible MIDI Device'.
My card is an Aztech Waverider32 with wave-table and it sound great!
P.S. Does anyone know someone who can play?
P.P.S If anyone knows of a better way or can suggest modifications to the above please let me know.
