פורסם 2003 בפברואר 2223 שנים למה Intel ?קח מפרט AMD "תותח":CPU : AMD Athlon XP 2400+ Tray CPU [ ¤ 1006.48 ] 1 Motherboards for AMD : Epox 8RDA+ NVIDIA nForce2 (DDR400, AGP8X, 5.1 Dolby Sound, ATA133, 1394, LAN, USB 2.0) [ ¤ 770.78 ] 1 Memory : DDR-RAM 256MB 3200 WinBond Memory [ ¤ 458.65 ] 1 CPU Cooling : Thermaltake Volcano 7 Plus CPU Cooler for AMD / Intel P4-478 !!! [ ¤ 120.63 ] 1 Hard Discs : Western Digital 80GB 7200 rpm 8MB Buffer ATA100 HDD [ ¤ 697.93 ] 1 Video Cards : Gigabyte RADEON 9700 Pro 128MB DDR Retail VideoCard [ ¤ 2068.92 ] 1 Floppy : Teac / Alps / Mitsumi 1.44MB 3,5" Floppy Drive [ ¤ 56.31 ] 1 CD-ROM / DVD-ROM : DVD-ROM BenQ 16/48 Retail [ ¤ 296.72 ] 1 Monitors : 19" CTX PR960F Flat Trinitron Monitor [ ¤ 2283.57 ] 1 Cases : Chieftec Dragon DX-01BLD Blue Tower (P/S not included) [ ¤ 444.77 ] 1 Power Supplies : HEC (Heroichi) 475VD-T Power Supply [ ¤ 399.95 ] 1 ¤ 8604.71
פורסם 2003 בפברואר 2223 שנים טוב;CPU : Intel Pentium IV 2.4GHz 512K 533MHz Socket 478 CPU BOX [ ¤ 1251.56 ] 1 Motherboards for Intel : Gigabyte GA-8SQ800 Ultra SIS 655 Motherboard (DualDDR,AGPx8,ATA133 RAID,5.1 Sound,1394,LAN,USB 2.0) [ ¤ 863.38 ] 1 Memory : DDR-RAM 512MB 3200 Winbond Memory [ ¤ 940.67 ] 1 CPU Cooling : Thermaltake Volcano 7 Plus CPU Cooler for AMD / Intel P4-478 !!! [ ¤ 120.63 ] 1 Hard Discs : Western Digital 80GB 7200 rpm 8MB Buffer ATA100 HDD [ ¤ 697.93 ] 1 Video Cards : Gigabyte RADEON 9700 Pro 128MB DDR Retail VideoCard [ ¤ 2068.92 ] 1 Floppy : Teac / Alps / Mitsumi 1.44MB 3,5" Floppy Drive [ ¤ 56.31 ] 1 CD-ROM / DVD-ROM : DVD-ROM BenQ 16/48 Retail [ ¤ 296.72 ] 1 Monitors : 17" CTX PR711F Flat Trinitron Monitor [ ¤ 1282.55 ] 1 Cases : Chieftec Dragon DX-01BLD Blue Tower (P/S not included) [ ¤ 444.77 ] 1 Power Supplies : HEC (Heroichi) 475VD-T Power Supply [ ¤ 399.95 ] 1 ¤ 8423.39
פורסם 2003 בפברואר 2223 שנים למה Intel ?קח מפרט AMD "תותח":CPU : AMD Athlon XP 2400+ Tray CPU [ ¤ 1006.48 ] 1 Motherboards for AMD : Epox 8RDA+ NVIDIA nForce2 (DDR400, AGP8X, 5.1 Dolby Sound, ATA133, 1394, LAN, USB 2.0) [ ¤ 770.78 ] 1 Memory : DDR-RAM 256MB 3200 WinBond Memory [ ¤ 458.65 ] 1 CPU Cooling : Thermaltake Volcano 7 Plus CPU Cooler for AMD / Intel P4-478 !!! [ ¤ 120.63 ] 1 Hard Discs : Western Digital 80GB 7200 rpm 8MB Buffer ATA100 HDD [ ¤ 697.93 ] 1 Video Cards : Gigabyte RADEON 9700 Pro 128MB DDR Retail VideoCard [ ¤ 2068.92 ] 1 Floppy : Teac / Alps / Mitsumi 1.44MB 3,5" Floppy Drive [ ¤ 56.31 ] 1 CD-ROM / DVD-ROM : DVD-ROM BenQ 16/48 Retail [ ¤ 296.72 ] 1 Monitors : 19" CTX PR960F Flat Trinitron Monitor [ ¤ 2283.57 ] 1 Cases : Chieftec Dragon DX-01BLD Blue Tower (P/S not included) [ ¤ 444.77 ] 1 Power Supplies : HEC (Heroichi) 475VD-T Power Supply [ ¤ 399.95 ] 1 ¤ 8604.71במפרט של 8500 שקל הייתי מוצא מקום לשני סטיקים של 256 אבל זה אני. אפשר לוותר על מארז וספק ב-850 שקל. חוץ מזה המפרט מצוייןותנסה פעם אחת AMD!! הלוחות אם החדשים מצויינים! INTEL=קקי!תבקש בפורום אחר כי כאן בודדים יתנו לך המלצה על INTELAMD ROCKS!
פורסם 2003 בפברואר 2223 שנים יכלת לסכם את המארז ואת הספק (במפרט הAMD) ב-FS-710 + EG365P-VE 350Watt של Enermax שעולה רק 750שקלים. יכלת לחסוך גם עם הקירור למעבד להפטר מהVolcano. הוא מאוד מיותר, יש מארז טוב, למרות שקירור למעבד אף פעם לא מזיק. הלוח מיותר גם הוא, אם לא מתוכנן אוברקלוק. פשוט לוקחים את הnForce2 של Leadtek ב600שקלים וחוסכים עוד 170שקלים.מסך 19"? אני לא יודע מה הוא רוצה, אבל מסכי 17" הם יותר מקובלים לשחקני מחשב. הייתי ממליץ על הMasterVision של Iiyama שעולה 1500, או על ה413 של CTX ואף גם הF700P של LG. בין כה וכה, חסכנו כ800-900שקלים עם המסך. עד כה, עם המסך, הקירור ושילוב המארז וספק, עם כל אלו חסכתי לך כ1400שקלים.נשאלת השאלה, מה עושים איתם, עם 1400 השקלים הללו? התשובה דיי ברורה. לוקחים AXP2700+ במקום הAXP2400+, שיעלה 2020ש"ח ועם המעבד גם סטיק זיכרון 256-333 של Winbond שיעלה 379ש"ח. (אגב, תפטר מה3200 וקח 2700, מה שמסתכם בשני סטיקים של 2700 שינצלו את הDualDDR שבnForce2)
פורסם 2003 בפברואר 2223 שנים תהרסו לבן אדם את התרד שלו .. לא מעניין את הסבתא שלו הamd שלכםאני מתפלא עליכם admins שלא השתקתם כמה אנשים פה עוד מקודם או יישרתם קואז כדאי שאו שמישהו יענו לו על פי ידע ונסיון או שבעלי הפה הגדול ישמרו את השטויות וההתנצחויות של מלחמת הamd intel למקום אחר כי הפורום כולו לא נראה טוב עם דברים שכאלהבעיקר כאשר התרד מככב באתר הראשי בהודעות האחרונות כבר עוד מעט יומייםתודה ולילה טוב
פורסם 2003 בפברואר 2323 שנים אני חושב שצריכים להשתיק אנשים כמוך, ולא אנשים שמביעים את דיעותיהם וממליצים למשתמש על מוצרים שונים.אנחנו, או אני לפחות, לא באים להטיף לו מוסר לגבי רכישת מעבד למחשב ביתי, אלא להמליץ לו על הטוב ביותר במסגרת תקציב המאקסימום שלו. זוהי זכותי להמליץ לו על מה שאני רוצה, מתי ואיך שרק מתחשק לי, אני לא עברתי על שום חוק מהחוקים של מערכת הפורומים. אני לא אכנס לויכוח של AMD Vs. Intel, אבל נגיד והוא עושה טעות ברכישת מעבד Intel. יהיה סבבה לא להעיר לו ולתת לו לשגות?נחש מה אני הייתי עושה במקומך עכשיו. לא, אני לא הייתי מנסה להציל את הכבוד שלי, אלא שהייתי מודה על הטעות שלי ומבקש סליחה על ההתקפה הלא-שפויה הזו. אני אמנם לא נעלבתי, אבל מגיעה לי התנצלות, בין כה וכה.
פורסם 2003 בפברואר 2323 שנים נחש מה אני הייתי עושה במקומך עכשיו. לא, אני לא הייתי מנסה להציל את הכבוד שלי, אלא שהייתי מודה על הטעות שלי ומבקש סליחה על ההתקפה הלא-שפויה הזו. אני אמנם לא נעלבתי, אבל מגיעה לי התנצלות, בין כה וכה. :-* אחי אמרתי INTEL ......לא AMD אין לי מה להוסיף סאלאם
פורסם 2003 בפברואר 2323 שנים אני קראתי את ההודעה הזו כבר. רגע, אתה ראית שאני הבאתי לו מפרט AMD? אני פשוט ביקרתי את המפרט שמשתמש אחר הביא.וגם אם הייתי מביא, אז זה כי אני ממליץ יותר על AMD, אני גם בין כה וכה התכוונתי לשאול אותו, ונראה לי שכבר שאלתי- למה Intel?
