Radeon 9500 on BX440, remember folks ?
two weeks ago i posted a thread about having R9500/9700 on a bx440 board and the question was if
this thing will work on such board
well, since im a certified lunatic and frankly insane i had to test this theor, i dont know why and for what but i have to share my expiriance with u ppl.
i got 3 boards, Ti4400, R9500pro and R9700 and run to my old abit BH6 with joy oh joy of seeing this cards operate on it
after spending a month on reading every possible info about AGP 1.0, 2.0, 3.0 and alot of other tech, i got confident that this thing should work right out of the box
i stuck the card in the agp slot, check everything is right and turned on the power ........... , the screen stayed black as the night ......., damn, i puld out the card and put the Ti to try again ...... NOTHING, NADA
the old bx just stayed off, i felt so miserable and unhappy !!!, WHY, WHY are life so mean to me
being insane as i am i took a dive to my old memory banks in a search of things that i have long forgotten to solve this unhappyness and there i found some more quirks that i can pull on the old bx
after playing around half a day, flashing bioses and manipulating every possible thing that i could think of, i reached to a point in which i thought that if this thing wont work i'll leave it in peace, there are some things that just not ment to be, i stuck the Ti, checked and double checked and turned the power
OH MY GOD, the screen came to life ..... i cant belive it, it real, im not dreaming .... windows loaded and asked for drivers and drivers he got, then i took a look in few games like U2 and MechWarrior 4 and u know what ?? 800 x 600 x 32 is preaty good for this old rig.
but wait, i wanted the R9700 right ?, i truned off the computer swaped the cards and turned it back on
ITS ALIVE, ALIVE I TELL YOU
windows came up once again and asked for drivers, i installed catalyst 3.1 and DX9 and the latest control panel and run the games again, MY MAN ... 1024 x 768 x 32, 63fps, damn life are sweettttttttttt
my old rig is the fallowing - Abit BH6 BX440, P933, 512Mb Infinio cas 2, WD 80GB 8mb cache, SBLive
OS - Win98, Win2k, WinXP
So, after being on a dark side and back to light, this thing works and works fine ... for all u ppl out there
dont lose hope of your dreams, thay might be near by just waiting for you to pick them up
my next project is Intel 286 and Unreal 2 in 1600 x 1200 x 32, 85fps, any one wona help :asthanos:
;D
Congrats!
רק שתדע לך המערכת שלך לא כזה דרעק ... הלוח והמעבד קצת אבל הזיכרון הההרד דיסק הכרטיס מסך ;D הם ממש סבבה !
ya, what he said.
nicely donE!
why in hell do you have those three diamonds? ( ;D )
Y, i know, this baby rocks, it can run things not like the newest P4 or Athlon 2800 but still good
with very playable framerates on all newgames that i tested and in 32bit, that was a complate surprize to me, i thougt that the system will hang or choke but it runs like hell, SWEET
מה כבר אוכל לומר...
קראתי את זה, וקיבלתי קצת תיקווה, אולי גם אני אוכל להכניס קצת חיים במחשב הגוסס שלי (פנטיום 3 450)
אני קורא קורא וקורא על מעללי ה-BX440 שלך וכשאני רואה שאתה מקבל תוצאות נהדרות עם הכרטיס אני בכלל נהיה מאושר
אך אויה(מילה מוזרה), אני רואה שהמעבד שלך "קצת" יותר חזק משלי אז כנראה שלי אין ממש סיכוי להחיות את המחשב שלי...
אבל כל הכבוד על העבודה...
יפה יפה, רק חבל שהייתי צריך בבילון בצד בשביל לקרוא את מה שרשמת :'(
הרצת 3DMARK 2001?
מעניין אותי לראות כמה קיבלת.
קבל ח"ח. WELL DONE !
Nicely done! It happens to me a lot that a part comes to life in mystries ways...
anyway.. I like to see some 3dmarks,,, 2001 and 03 if u can.
MOOMOO
Hello ppl
Since meny of you asked for 3dmark benchmark i did it and tested the system 4 times
in the 2001 SE version Build 330, about 2003, im still running few tests
my score with R9500 Pro and P3 800 is 5735 in 1024x768x32
Win98, Catalyst 3.1, DX9
the R9700 Pro was not tested yet
what do you think of this ?
is it the 2001 score or the 2003?
if it's the 2003, it's amazing... if it's the 2001, u could check the ORB ...
נחמד, רק חבל שהמחשב שלך לא מנצל את כל הפוטציאל הגלום של
ה Radeon 9500 PRO..
אתה מציל מחשב מהמוות..
