זקוק לדעות על סורק
Model HP Scanjet 2400C
Optical scanning resolution Up to 1200 dpi
Hardware scanning resolution Up to 1200 x 1200 dpi
Enhanced scanning resolution Up to 999999 enhanced dpi
Bit depth 48-bit
Gray scale levels 256
Scan speed in preview mode 12 secs
Scan speed (OCR, A4) < 45 secs
Scan speed footnote * Scan Speed: results of HP internal tests carried out on a 1.70 GHz HP Vectra PC with 256 MB of RAM/Microsoft® Windows® 98; scan speed, preview: the scanner lamp has been warmed up and time is measured from mouse click/button push, ending when the image of the platen is visible and the user has control.
Maximum scanning size 21.59 x 29.72 cm
Dimensions (W x D x H) 458 x 275 x 615 mm
Weight 2.20 kg
Power consumption 17 watts maximum
Power supply type external power adapter
Warranty 1 year limited hardware warranty; 30-day telephone support backed by HP Customer Care; 24-hour electronic support available free at the following site: www.hp.com/support
אני לא בקיא בפרטים הטכניים. עבור 370 שקל, זה נחשב סורק טוב?
פעם הבאה תשלח קישור,יותר פשוט.
תוסיף 100 שקל בערך תקח קנון LIDE 70,הרבה יותר טוב ועם 3 שנים אחריות.
