פורסם 2003 בפברואר 523 שנים Hello hwzone...I have no Hebrew on this friggin' keyboard, I appologize...I am having problems with this board. I just bought it and installed Win98se and WinXP Pro + SP1.I am experiencing sound problems on Win98se. No device are installed although I installed the drivers.On BOTH OS's I have shut down problems. The PC cannot shut down by itself unless I MANUALLY press the power button and only then it goes down.Does someone here have this board?Can someone help me here please?Thank-you...!
פורסם 2003 בפברואר 523 שנים i have this board first for hebrew go to control panel<date,time....<riegonal and language optionschnage in there every thing to hebrew the sound problem i dont have it but i ihink that if u download the driver 1.16 it will work fine here link the shut down problem u fix bygoing to divce manager then press on show hidden divices (it in view)then u probbley see something with xi think atm or sometihng like thisjust enabel it
פורסם 2003 בפברואר 523 שנים מחבר Thank-you Mephisto...Apparantely the sound issue is only in WIn98se. In WinXp Pro it does not happen. I installed the AsusnForce2_1.16 unified driver package and it immediately identified the sound devices...In Win98se it is another story completely.Regarding the shut down problem, someone else also told me about this thing to check in the device manager, but where EXACTLY is it? I checked "show hidden devices" but I saw no red 'X' mark.Please be more specific on that.Besides the 1.16 UDP from Asus, did you have to install anything else manually or regularly?Any other drivers I should know of?Thanks,LIOR
פורסם 2003 בפברואר 523 שנים i think the option in the dive manager is acpi fixed feature buutemlook for it in there take a look on this asus a7n8x\delux FAQ here something from the faq about the win98 & sound card"Q. I have windows98 or SE and i cant get any sound working, i have installed the drivers but there is a problem in the device manager. How do i get sound working in windows98 or 98SE?" A. There is a hot fix for windows98 and 98SE that needs to be installed in order for the sound on your motherboard to work properly. You can find more information about the hot fix here and download the patch here. There is also another patch you should have installed, you can find it here. Also make sure that if you are using the 2.0 drivers from nVidia then to check above, as there is some important information about those drivers being installed on a7n8x-deluxe boards. and nothe driver 1.16 have all the driver for all the things whoes related to board the only other dirver u need is of the vga, modem, etc....and what about the hebrew u fix it?ohh and it mafistothere is another user in here whos cald maphisto (oc\modding moder)
פורסם 2003 בפברואר 523 שנים מחבר יש עברית ... (שוב תודה לך Mafisto . חשבתי שזה Mephisto כמו היצור הרע ב-Diablo 2 ) טוב, אני אחפש את האופציה הזו תחת מנהל ההתקנים כשאגיע הביתה. משום מה נראה לי שהאופציה הזו ראיתי אותה והיא לא היתה באדום. חוץ מזה מה יש לשנות שם? יש שם איזה Check box שעליי לסמן או משהו כזה? לגבי ה-Sound אני אברר את זה. אגב אילו מערכות הפעלה יש לך במחשב? אתה עובד עם ה-OnBoard Sound ? ניצלת אותו במלואו עם מערכת 5.1 ? אגב מאיפה אתה בארץ?
פורסם 2003 בפברואר 523 שנים השם לקוח מדיאבלו 2 אבל באות תקופה לא ידעתי הכי טוב אנגלית על האפשרות הזאת אתה פשוט צריך לעשות ENABEL במידה והוא על DISABEL אני משתמש בכרטיס קול OB אבל יש לי רק מערכת של 2 רמקולים (גדולים) אבל יש איזה משהו נחמד שם שאם אתה מפעיל את הפענוח DD ושם אתה ההגדרות על מערכת 5.1 הוא נותן לך ערוצים מדומים ממש לא נשמע כמו משהו אמיתי אבל אופציה נחמדה אני עובד עם XP רק.. אין לי כוח להתחיל להתקין את ה98 עם כל הבעיות שלה אני מקיבוץ חולדה זה במרכז...
פורסם 2003 בפברואר 623 שנים מאיפה לקיבוצניק יש כלכך הרבה כסף להוציא על מחשב ?: P סתם, יש לך מחשב פיצוץ, לא הייתי קונה משהו אחר, כמעט הלוואי עליי.
פורסם 2003 בפברואר 623 שנים למה כל הזמן חושבים שקיבוצניקים כאלה עניים? זה כסף שהרווחתי מעבודה של איזה חצי שנה בערך ... 8)
