מפרט הכרטיסים- HD2600/HD2400!
הנה לפניכם המפרט:
SAPPHIRE to launch new ULTIMATE graphics solution
HD 2600 and HD 2400 series include special editions
SAPPHIRE Technology has just announced that in addition to the new HD 2600 and HD 2400 series of graphics accelerators scheduled for release in July, the range will include the new completely passively cooled SAPPHIRE HD 2600 XT ULTIMATE Edition.
SAPPHIRE’s ULTIMATE Editions are renowned for the key features of overclocking for enhanced performance and silent running. The low power consumption of this new generation of GPU’s allows a totally passive cooling solution to be used whilst achieving top levels of performance in it class.
The SAPPHIRE HD 2600 XT ULTIMATE Edition features the latest unified shader architecture with 24 shader pipelines, a 128-bit memory bus and high speed GDDR3 memory. Other family members include the SAPPHIRE HD 2600 PRO with a similar architecture but using GDDR2 memory. Also available are the SAPPHIRE HD 2400 XT and SAPPHIRE HD 2400 PRO, cost effective solutions with 8 unified shader pipelines and a 64-bit memory interface using GDDR3 and GDDR2 memory respectively.
Both of the HD 2600 and HD 2400 series’ also incorporate the latest ATI Avivo™ HD Video & Display Technology. An exciting new feature is the built in hardware UVD – a dedicated Unified Video Decoder that accelerates the decoding of Blu-ray™ and HD DVD content with dramatically reduced load on the system CPU, making even the low-end cards in the series ideal for media centre applications.
Two Dual Link DVI outputs are provided on all models. HDMI users are supported with another new feature that Multi-Channel 5.1 Audio is integrated onboard with the graphics output to provide true audio and video output via an HDMI adapter for direct connection to an HDMI ready TV.
Developed to natively support the latest applications using Microsoft Direct X® 10 and Shader Model 4.0, for a whole new generation of performance, this series brings new meaning to the Windows Vista™ Premium Experience.
SAPPHIRE is already shipping its new flagship model the SAPPHIRE HD 2900 XT. Other products in the family are scheduled for delivery in July.
תגידו, מהירות הזיכרון שרשום שם היא בהכפלה או ללא הכפלה?
לי דווקא נראה שזה ללא הכפלה, בכל מקרא ציפיתי קצת ליותר...
ההפרש בין המיינסטרים להיי-אנד גדול מאי פעם...
אני מציע חרם צרכנים על NV/AMD עד שיתאפסו על עצמם בתחום הביצועים פר שקל :xyxthumbs:
אני מחכה לבאנצ'מארקים... לראות מי שולט בבית.
לא מצויין כמה סטרים פרוססורס ומה בקר הזיכרון שלהם...
צריך לדאוג למיינסטרים יותר, אחרי הכל זה הזרם המרכזי ומה שמביא לחברות את הBIG BUCKS כולל הLOW END... עכשיו שמעתי שATI עושים את הטעות המרה של NVIDIA, שמים 128 ביט זיכרון בHD2600 ובHD2400PRO הם שמים בקר זיכרון 64 ביט!!!!! חרם!!!!!! זה עלוב בצורה לא יאומנת.
דור ה-main stream הנוכחי ממש מאכזב , חבל שכל מה ש-NV עושה גרוע , ATI עושה עוד יותר גרוע
סוף סוף יש תחרות , מי עושה כרטיסי main stream יותר עלובים
הזלזול בMAINSTREAM נמשך, צריכים לענות לדרישה שלנו זה יגדיל להם תרווחים מה אכפת להם???? לעזעזל מתי יהיה כרטיס MAINSTREAM עד 1400 שיהיה עם 256ביט 512זיכרון ויריץ כל משחק על ההגדרות הכי גבוהות בלי בעיה לפחות עם חצי מהפילטרים?
בשביל זה יש high end...
הרי ממילא רוב האנשים קונים את הזבל מהעיתון עם הכרטיס ב-400 שקל...
ומי שרוצה ביצועים מוכן להשקיע בשביל high end...
זה פשוט לא כלכלי להם.
תראו מה זה, מוציאים כרטיסים פחות טובים למשחקים ועוד המשחקים של DX10 כדוגמת LP ו-Dirt זללני גראפיקה שכמותם...... צריך לחכות עוד ועוד ועוד למשהו האמיתי הזה :-\.
זאתי בדיוק הבעיה, שאם היו מביאים את הHIGH END לMAINSTREAM זה היה צעד מאוד מבורך, ואז היו שוללים את הHIGH END. אבל זה המצב אם הMAINSTREAM לא ישתפר אני לא חושב שיהיה כבר שווה להשקיע בכרטיסי מסך.
