Stability Issues!!!!!!
Hi
I have the system listed in my profile.
i wanted to preform a minor OC , i wanted to push the CPU to 2.7GHz and leave it that way 24 7.
i did it, the temprature is 35 idle and 48 under load
i didnt change the voltage, the RAM is running at 900MHz but its same thing when it was running at 800MHz.
the proplem is, i can run 3dmark06 without a crash
i worked in the computer for all almost all day that way the tempruture was okey
the proplem is, i dont feel the system stable . if i run everest stability test i get some errors after 2 minutes while i get no error in SP2004.
i ran a game it crashed after 4 minutes with artifacts on the screen and ATI vpu recover jumped saying there was a proplem with the graphic card and it had to be stoped.
for the system i have this OC should be easy and ive got higher clocks on stock voltage before, any ideas why is this happening? and why am i getting artifacts? ain the graphic card responsiable for that?
note: id ont wanna push it more than 2.7 in the meanwhile couse i have the stock intel cooler, when i find a good cooler that fits in my case ill push it further
note:
yeah the PCI-e is locked
הכרטיס שלך בOC ?
"נעלת" את ה-Spread Spectrum ?
נסה להוריד את הזיכרונות לתדר העבודה שלהם 800MHz או מתחת על מנת לשלול את הבעיה (למרות שהם לא צריכים להיות הבעיה)...
the card is not OC'ed
i did lower the memory to 800Mhz after OC (712MHz before the OC)
i belive the spread spectrum is set to auto, should i disable it?
today ive noticed some artifacts nothing serious, like a fast flash throw the screen,while playing a game while i was at stock, could it be that the graphic card ??
כן... ;D
תבדוק את הטמפ' של הכרטיס מסך במנוחה/מאמץ..
i dont have sensors on the graphic card so i cant tell the tempreture
אין לך חיישן טמפ' בכרטיס מוזר (עד כמה שזכור לי בX1600 למיניהם יש)..
ונסה לעלות מתח לציפסט וכו...
i have X1600Pro from pailit, i got it really cheap back then so i wasnt surpirised it doesnt have sensors
i did update my drivers from catalyst 6.12 to 7.4, ill check if that helps when this heat cool down a bit!!!!
