מחירי AMD התעדכנו
Sort by Popularity | Sort by Rating | Sort by Price
Athlon 64 X2 3800+ Processor (2.0GHz, 1MB, 1GHz FSB, Socket AM2) AMD Athlon 64 X2 3800+ Processor
AMD - ADO3800CUBOX
Rating: 4.5 Star Review (6 Reviews) $5.00 Bonus!
from $79.00
(28 Sellers)
Check Prices
Athlon 64 X2 3600+ Dual Core Processor (2.0GHz, 2x256KB, 1GHz Bus, Socket AM2) AMD Athlon 64 X2 3600+ Dual Core Processor
AMD - ADO3600CUBOX
Rating: Write a Review $5.00 Bonus!
from $79.05
(2 Sellers)
Check Prices
Athlon 64 X2 3600+ Processor (1.9GHz, 2x512MB, 1000MHz Bus, Socket AM2) AMD Athlon 64 X2 3600+ Processor
AMD - ADO3600DDBOX
from $79.05
(15 Sellers)
Check Prices
Athlon 64 X2 4200+ Dual Core Processor (2.2GHz, 1MB, 1GHz Bus, Socket AM2) AMD Athlon 64 X2 4200+ Dual Core Processor
AMD - ADA4200CUBOX
Rating: 4.5 Star Review (10 Reviews)
from $99.90
(28 Sellers)
Check Prices
Check Prices
Athlon 64 X2 Dual-Core Processor (2.1GHz, 2x512kB, 1000MHz Bus, Socket AM2) AMD Athlon 64 X2 Dual-Core Processor
AMD - ADO4000DDBOX
from $112.98
(20 Sellers)
Check Prices
Athlon 64 X2 4600+ Dual Core Processor (2.4GHz, 1MB, 1GHz Bus, Socket AM2) AMD Athlon 64 X2 4600+ Dual Core Processor
AMD - ADA4600CUBOX
Rating: 5 Star Review (7 Reviews) $10.00 Bonus!
from $113.40
(27 Sellers)
Check Prices
Athlon 64 X2 4800+ Dual Core Processor (2.5GHz, 2x512KB, 1GHz Bus, Socket AM2) AMD Athlon 64 X2 4800+ Dual Core Processor
AMD - ADO4800DDBOX
from $129.00
(19 Sellers)
Check Prices
Athlon 64 X2 4400+ Dual Core Processor (2.3GHz, 2x512MB, 1GHz Bus, Socket AM2) AMD Athlon 64 X2 4400+ Dual Core Processor
AMD - ADO4400DDBOX
from $129.00
(21 Sellers)
Check Prices
Athlon 64 X2 5000+ Dual Core Processor (2.60GHz,1MB, 800MHz, Socket AM2) AMD Athlon 64 X2 5000+ Dual Core Processor
AMD - ADA5000CSBOX
Rating: 4.5 Star Review (2 Reviews) $5.00 Bonus!
from $159.00
(30 Sellers)
Check Prices
Athlon 64 X2 5200+ Dual Core (2.6GHz, 2x1MB, 1GHz FSB, Socket AM2) AMD Athlon 64 X2 5200+ Dual Core
AMD - ADA5200CSBOX
Rating: 5 Star Review (7 Reviews) $5.00 Bonus!
from $169.00
(29 Sellers)
Check Prices
Athlon 64 X2 5600+ Dual-Core Processor (2.8GHz, 2x1MB, 1GHz Bus, Socket AM2) AMD Athlon 64 X2 5600+ Dual-Core Processor
AMD - ADA5600CZBOX
from $179.00
(18 Sellers)
Check Prices
Athlon 64 X2 6000+ Processor (3GHz, 2x1MB, 1GHz Bus, Socket AM2) AMD Athlon 64 X2 6000+ Processor
AMD - ADX6000CZBOX
Rating: 4 Star Review (1 Review)
from $229.00
(20 Sellers)
Check Prices
  • תגובות 122
  • צפיות 12.7k
וואי ה4800 ב129$ וה4600 ב113$ מחירים שווים לכל כיס.
אני חושב שמגמת הקנייה תלך יותר לכיוון ל AMD עכשיו לפחות עד שאינטל יורידו מחירים.
ה4800 הוא ברמה של 6300?
אינטל הורידו כבר,לפחות בחו"ל.
וה-4800 חזק מה-6300 בסטוק
ממשיך את הרעיון:
אין היום לAMD מה להציב מול C2D בOC .
גם אם הוא יותר חזק בסטוק, אחרי OC קטן עד בינוני C2D יותר חזק.
אינטל הורידו?? אני לא חושב בדקתי עכשיו בnewegg והמחירים עדיין לא השתנו רק אלו של AMD.
שזה גם הגיוני כי עדכון המחירים של אינטל צריך להתבצע ב22 לחודש.
ממשיך את הרעיון:
כן אבל יש הרבה משתמשים שלא יודעים איך ופוחדים לעשות,אז זאת אופציה טובה בשבילם.
האם הורדת המחירים תשפיע גם על מעבדי 939 כפולי הליבה? ואם כן נראה לכם שבארץ יורידו את המחיר שלהם או שהם ישאירו את המחיר כמו שהוא?
תודה.
:xyxthumbs:
שום דבר מהורדות המחירים האלה לא קשור ל-939
המחירים תקפיפ גם בארץ? ואם כן ממתי
ומה אם 3800 DUAL לא ראיתי את המחיר ברשימה.
אי אפשר לדעת מתי זה יגיע לארץ...
וה-3800 הוא הראשון
אבל זה 3800 רגיל אני שאלתי על כפול ליבה
מישהו יכול "לתרגם" את המחירים למחיר שצפוי בארץ?
AMD - ADO3800CUBOX
from $79.00
אי אפשר. תחכה ותראה
טבלה מסודרת מxs
