פורסם 2007 במרץ 2719 שנים הנה סכמה: Here is a simple transmitter that when connected to a phone line, will transmit anything on that line (execpt the dial tone) to any FM radio. The frequency can be tuned from 88 to about 94Mhz and the range is about 200 feet. It is extremely easy to build and is therefore a good, useful beginner project. Part Total Qty. Description Substitutions R1 1 180 Ohm 1/4 W Resistor R2 1 12K 1/4 W Resistor C1 1 330pF Capacitor C2 1 12pF Capacitor C3 1 471pF Capacitor C4 1 22pF Capacitor Q1 1 2SA933 Transistor D1, D2, D3, D4 4 1SS119 Silicon Diode D5 1 Red LED S1 1 SPDT Switch L1 1 Tuning Coil MISC 1 Wire, Circuit Board Notes 1. L1 is 7 turns of 22 AWG wire wound on a 9/64 drill bit. You may need to experiment with the number of turns. 2. By stretching and compressing the coils of L1, you can change the frequency of the transmitter. The min frequency is about 88 Mhz, while the max frequency is around 94 Mhz. 3. The green wire from the phone line goes to IN1. The red wire from the phone line goes to IN2. The green wire from OUT1 goes to the phone(s), as well as the red wire from OUT2. 4. The antenna is a piece of thin (22 AWG) wire about 5 inches long. 5. All capacitors are rated for 250V or greater. 6. The transmitter is powered by the phone line and is on only when the phone is in use. S1 can be used to turn the transmitter off if it is not needed. 7. If you have problems with the LED burning out, then add a 300 ohm 1/4W resistor in series with it. הנה הקישור לאתר: http://english.cxem.net/radiomic/bug17.php איך זה עובד מה בידיוק זה עושה? איזה חלקים צריך? אשמח אם תעזרו לי בנושא הזה
פורסם 2007 במרץ 2719 שנים cool one! ;D 1) this circuit is built to transmit the calls or anything in the phone line to a FM radio.... example...: your sister is talking on the phone with her man.... (for example yes.... ) and suddenly!!! any one who's on...... lets say.. 92hz... can listen to them!! (for ....66 meters !!) 2) you have the parts list..... (actually.. you also have a description for the first question.. but never mind) Odedb52
פורסם 2007 במרץ 2819 שנים מחבר תודה, אבל הייתי שמח אם מישהו היה מסביר לי איך זה עובדוזה גם לא כזה טוב כי לא רק אתה יכול לשמוע!!! אלא כל מי שמפעיל רדיו
