פורסם 2007 במרץ 1919 שנים שלוםאני מעוניין לרכוש כרטיס מסך ל AGP מה אתם אומרים על הכרטיס הזה?RADEON X1950PRO, 256MB GDDR 3, AGP 8X, HDCP Edition GC-HV195PGA3-D3 (RoHS) VPU RV570 (80nm) Memory 256MB GDDR3 Bus support AGP 8X HDTV Support HDCP compliant High-bandwidth Digital Content Protection Enabled The images is for reference only; actual spec.and PCB color are based on the real product Product Description The Radeon® X1950Pro series is designed to deliver outstanding digital entertainment and 3D graphics through its unique ultra-threaded architecture and Avivo video and display technology. Designed with cost effective native HDCP (High-bandwidth Digital Content Protection) implementation as a requirement for Blu-ray and HD DVD applications. Radeon X1950Pro is an ideal product for the 3D gaming and delivers superior visual performance for all types of PC entertainment. GeCube Awards Product Features Powered by ATI RADEON® RV570 (80nm) GPU A 80-nanometer process GPU, the debut of the unique processing architecture 256MB of 256-bit (512-bit Internal Ring Bus) GDDR3 memory 36 parallel pixel pipelines Dual DVI (Double Dual Link) + HDTV + HDCP + D-sub support. ATIs Avivo technology connects to home entertainment devices and creates true-to-life image reproduction, and the smoothest video playback ever offered by ATI. Get high image fidelity with CRT and LCD displays, TVs, rear projection and plasma TVs, and projectors. New ultra-threaded core 3D architecture with ATIs revolutionary Avivo video and display technology to drive performance to new heights with incredible speed and intense 3D graphics. Shader Model 3.0 features new High Dynamic Range visual effects, and enhances realism with adaptive anti-aliasing and lightening fast performance. CATALYST: Full Windows Vista LDDM support including Aero Glass visuals אני מעוניין לרכוש אותו מפנדה ב 1300 שקליםזה כדאי ?ואם לא אז איזה כרטיס אתם ממליצים ?הוא חייב להיותAGP אבל ותקציב זה לא בעיה ואם זה אותו כרטיס בגירסת 512 מגה אז אין טעם להציעאיך הם בשירות?כמה זמן לוקח להם עד שהם מספקים מוצרים ?
פורסם 2007 במרץ 1919 שנים לא יודע על הכרטיס אבל השירות סבבהעם אתה מזמין אז לך לסניף תל חנן יש שם איזה עובד שמבין עיניון לא כמו כל שאר החניות
פורסם 2007 במרץ 1919 שנים אחלה כרטיס, אבל במקומך לא הייתי משקיע בכרטיס מסך ל-AGP אם אתה רוצה אותו למשחקים ולהרבה זמן...
