פורסם 2007 במרץ 919 שנים הנה הLOG של הצריבה, החרא פשוט מסרב לצרוב!!NEC 3540Aאני מנסה לצרוב דרך NERO..דיסק של DATA של מפי3 וWMA.1C82-0000-19E5-MAAX-4003-6439-8760Windows XP 5.1IA32WinAspi: -ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 13:54:32 PM NT-SPTI usedNero Version: 7.2.0.3Internal Version: 7, 2, 0, 3Recorder: <_NEC DVD_RW ND-3540A> Version: 1.01 - HA 1 TA 0 - 7.2.0.3 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ?CD-ROM: <HY1581T BEW352M >Version: 1.0 - HA 1 TA 1 - 7.2.0.3 Adapter driver: <SCSI> HA 1=== Scsi-Device-Map ===CdRomPeripheral : _NEC DVD_RW ND-3540A atapi Port 1 ID 0 DMA: On DiskPeripheral : WDC WD1200JD-00HBB0 08.0 viasraid Port 2 ID 0 DMA: OffCdRomPeripheral : HY1581T BEW352M 1.0 dtscsi Port 3 ID 0 DMA: OffCdRomPeripheral : HY1581T BEW352M 1.0 dtscsi Port 3 ID 1 DMA: OffCdRomPeripheral : EK0213O VAR172C 2.0B vaxscsi Port 4 ID 0 DMA: Off=== CDRom-Device-Map ===_NEC DVD_RW ND-3540A E: CDRom0HY1581T BEW352M F: CDRom1HY1581T BEW352M G: CDRom2EK0213O VAR172C H: CDRom3=======================AutoRun : 1Excluded drive IDs: WriteBufferSize: 83886080 (0) ByteBUFE : 0Physical memory : 1022MB (1047280kB)Free physical memory: 330MB (337980kB)Memory in use : 67 %Uncached PFiles: 0x0Use Inquiry : 1Global Bus Type: default (0)Check supported media : Disabled (0) 9.3.2007CD-ROM (ISO)23:52:29 PM #1 Text 0 File Isodoc.cpp, Line 6424 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE23:52:29 PM #2 Text 0 File Burncd.cpp, Line 3068 _NEC DVD_RW ND-3540A Buffer underrun protection activated23:52:29 PM #3 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 81920KB of Memory23:52:29 PM #4 Text 0 File Reader.cpp, Line 124 Reader running23:52:29 PM #5 Text 0 File Writer.cpp, Line 113 Writer E: _NEC DVD_RW ND-3540A running23:52:29 PM #6 ISO9660GEN -11 File Geniso.cpp, Line 3312 First writeable address = 0 (0x00000000)23:52:31 PM #7 Text 0 File Burncd.cpp, Line 3365 Turn on Disc-At-Once, using CD-R/RW media23:53:06 PM #8 Text 0 File DlgWaitCD.cpp, Line 289 Last possible write address on media: 359846 ( 79:59.71) Last address to be written: 343647 ( 76:23.72)23:53:06 PM #9 Text 0 File DlgWaitCD.cpp, Line 301 Write in overburning mode: NO (enabled: CD)23:53:06 PM #10 Text 0 File DlgWaitCD.cpp, Line 2715 Recorder: _NEC DVD_RW ND-3540A23:53:06 PM #11 Text 0 File DlgWaitCD.cpp, Line 473 >>> Protocol of DlgWaitCD activities: <<< ========================================= Insert the disc to write to. (Medium in drive: Unknown. Medium required by compilation: CD-R/RW.)23:53:06 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 343648 (343648) = #343648/76:21.73 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 343648 blocks [E: _NEC DVD_RW ND-3540A] --------------------------------------------------------------23:53:06 PM #13 Text 0 File Burncd.cpp, Line 3960 Can only write at 32x (4,800 KB/s) instead of 48x (7,200 KB/s) to current disc.23:53:06 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [E: _NEC DVD_RW ND-3540A] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 704098304, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0x00 -150 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 343648 | lead-out | 1 | 0x41 | 0x0023:53:06 PM #15 Text 0 File SCSIPassThrough.cpp, Line 39 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME23:53:06 PM #16 Text 0 File SCSIPassThrough.cpp, Line 84 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME23:53:06 PM #17 Phase 24 File dlgbrnst.cpp, Line 1730 Caching of files started23:53:06 PM #18 Text 0 File Burncd.cpp, Line 4199 Cache writing successful.23:53:06 PM #19 Phase 25 File dlgbrnst.cpp, Line 1730 Caching of files completed23:53:06 PM #20 Phase 36 File dlgbrnst.cpp, Line 1730 Burn process started at 32x (4,800 KB/s)23:53:06 PM #21 SPTI -1189 File SCSIPassThrough.cpp, Line 290 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1189) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x02 CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 02 Buffer x05c21a00: Len x400023:53:06 PM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2707 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #023:53:06 PM #23 Text 0 File MMC.cpp, Line 17284 StartDAO : CD-Text - Off23:53:06 PM #24 Text 0 File MMC.cpp, Line 21963 Set BUFE: Buffer underrun protection -> ON 23:53:07 PM #25 Text 0 File MMC.cpp, Line 17515 CueData, Len=32 41 00 00 14 00 00 00 00 41 01 00 10 00 00 00 00 41 01 01 10 00 00 02 00 41 aa 01 14 00 4c 17 49 23:53:27 PM #26 SPTI -1106 File SCSIPassThrough.cpp, Line 290 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 00 FF FF FF 6A 00 00 20 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03 Buffer x0d490000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23:53:27 PM #27 CDR -1106 File Writer.cpp, Line 302 Power calibration error E: _NEC DVD_RW ND-3540A23:53:27 PM #28 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion23:53:27 PM #29 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader23:53:27 PM #30 Phase 38 File dlgbrnst.cpp, Line 1730 Burn process failed at 32x (4,800 KB/s)Existing drivers:File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 5/19/2006 23:16:24 PM File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 5/16/2006 22:23:54 PM (Prassi/Veritas driver for win 2K)File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 8/4/2004 3:07:00 AM (Adapter driver for src)Registry Keys:HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
