פורסם 2007 במרץ 219 שנים אני לא ראיתי השוואה כזו (וגם אני לא חושב שיש שני מארזים כאלה)לדוגמא יש מספר מארזים ל - TT שההבדל היחיד ביניהם זה החומר ממנו הם עשויים (יש שתי גרסאות לכל אחד), כמו ה: AGUILA, ARMOR,KANDALF,ARMOR JUNIOR.
פורסם 2007 במרץ 219 שנים המאמר הקטן שדיברתי עליו קודם לגבי אלומיניוםALUMINUMThe Aluminum Myth - Some favor aluminum cases, citing an ability to better cool components mounted within. This is a myth. No heat producing component benefit in any significant way from being inside an aluminum case. The only heat producing devices that are normally mounted in direct contact with a case are the drives, particularly the hard drives. The difference between aluminum and steel in this cooling function is insignificant.This does not mean aluminum cases cannot be used to make a silent computer, just that there are disadvantages with them when compared to similarly constructed steel cases. Regardless, many aluminum cases certainly look nice.The Aluminum Drawback - One consistent acoustic property seems unavoidable: Aluminum cases tend to pick up hard drive and fan vibrations more readily than steel cases, and make a higher pitched, more audible humming or buzzing sound. This quality is directly related to the density of aluminum: It has only about 30% of the density of the cheaper, more commonly used steel. Internally applied panel damping materials (especially the heavier kinds) appear to damp the resonance down fairly effectively, but it can be difficult and expensive to eliminate entirely. Internal supporting cross braces that effectively divide the large panels into smaller ones also help quite a lot because smaller panels are more rigid, stiffer, and less prone to lower frequency vibration than larger ones.Some case makers have sought to combine the desireable look of aluminum with the sturdiness of steel by using a front facia or bezel made of aluminum on a steel chassis. The Silverstone LC-11 media PC case and the Coolermaster Centurion 5 midtower are good examples of this type of hybrid case. http://www.silentpcreview.com/article75-page2.html
פורסם 2007 במרץ 219 שנים תודה דור.ידעתי שאני צודק בזה שהאלומיניום לא תורם באופן משמעותי לקירור המארז.
פורסם 2007 במרץ 219 שנים כן וכמו שאתה רואה יש לו גם כמה וכמה חסרונות,היתרון העיקרי שלו אני מאמין זה שהוא קל אבל כמה אנשים באמת צריכים מארז קל?
