VIA Hyperion 4in1 drivers
VIA have led the way in pioneering the unified driver set. The VIA 4in1 drivers, often known as a VIA 4in1 service pack have been the mainstay of VIA systems for years - optimizing stability and comparability. Today (10 December 2002) is an historic occasion, as VIA changes the name to VIA Hyperion 4in1 drivers and launches the driver set, optimized for performance for VIA's latest chipsets. The name Hyperion will most certainly supercede the name 4in1 all together in the future, but "4in1" has been kept in the name for identification sake. The version numbers also continue on from the 4in1 driver series so as not to confuse our customers.
Users downloading drivers for mainboards with either a VIA Apollo KT400 chipset or VIA Apollo P4X400 chipset are strongly advised to chose the VIA Hyperion 4in1 v4.45 drivers for enhanced performance. (
More information)
התקנתי את הדריבר החדש, היה אתמול בערב מוס על חברת VIA ובקושי היה אפשר למשוך את הקובץ.
נראה לי כי חל שיפור במערכת
אגב אני מריץ 1800+ עם לוח גיגה בייט 7VAX
