לא בדיוק ביאליק.... אבל עדיין שיר נחמד.
משהו נחמד - תנסו לקרוא את זה בקול
If a packet hits a pocket on a socket on a port, and the bus is interrupted at a very last resort, and the access of the memory makes your floppy disk abort, then the socket packet pocket has an error to report.
If your cursor finds a menu item followed by a dash, and the double-clicking icon puts your window in the trash, and your data is corrupted cause the index doesn't hash, then your situation's hopeless and your system's gonna crash!!
If the label on the cable on the table at your house says the network is connected to the button on your mouse, but your packets want to tunnel to another protocol, that's repeatedly rejected by the printer down the hall, and your screen is all distorted by the side effects of gauss, so your icons in the window are as wavy as a souse; then you may as well reboot and go out with a bang, 'cuz sure as I'm a poet, the sucker's gonna hang!
When the copy of your floppy's getting sloppy in the disk, and the macro code instructions cause unnecessary risk, then you'll have to flash the memory and you'll want to RAM your ROM.
חביב, אתה כתבת?
אני לא עד כדי כך מוכשר....
ב-00:55 השכנים שלי שומעים אותי מדקלם אנגלית....
חמוד.
this > bialik
מעולם לא הייתי חובב של ביאליק.
חמוד מאד ;D
:סמייליעומדעלהרגלייםמוחאכפיים:
חמוד מאוד!! מזכיר לי את "בא עם גרביים" של דוקטור סוס :)
Damm this song own, im going to play it with my organ
;) ill record it and publish it in the internet, then MTV will hear it and ill get rich and famus Then.... ill be MultiBulti Xillioner and then ill buy Hwzone a new server, with ten xeon proccessors and if there is no mobo for it ill order a specail one from ASUS and thennnnnnn ill be happy and ill buy myself the world.
btw : pure spam! :-X
