גובהו של מסך Lg l194Wt
היי.
האם מישהו יכול להגיד לי מה גובהו של מסך Lg l194Wt
בתודה.
Manufacturer LG Electronics
Manufacturer Part Number L194WT-SF
Product Name L194WT LCD Monitor
Product Type LCD
Product Model L194WT
Technical Information
Number of Screen(s) 1
Actual Screen Size 1 x 19"
Viewable Screen Size 19"
Projection Technology Active Matrix TFT
# Screen Surface Anti-reflective
# Anti-static
Dot Pitch 0.283mm Horizontal
# Input Signal Analog
# Digital
Monitor Response Time 5 ms
Tilt/Swivel 25° Up | 5° Down Tilt
# Viewing Angle 160° Horizontal
# 160° Vertical
Mountable Wall-mountable - VESA
# Platform Support PC
# Mac
Display & Graphics
# Resolution 1440 x 900
# 1280 x 1024 @ 75Hz
Maximum Resolution 1440 x 900
Colour Support 16.2 Million Colors
# Scanning Frequencies 30 kHz to 83 kHz Horizontal
# 56 Hz to 75 Hz Vertical
Contrast Ratio 2000:1
Brightness 300 cd/m²
Interfaces/Ports
# Interfaces 1 x 15-pin D-Sub
# 1 x DVI-D (Digital)
Power Description
Input Voltage 110 V AC or 220 V AC
Physical Characteristics
Colour Silver
Dimensions 37cm Height x 43.5cm Width x 22.6cm Depth
Weight 3.6 kg
Miscellaneous
# Additional Information Plug & Play: VESA DDC 1 & 2B
# LIPS(LCD Integrated Power Supply)
Warranty
Standard Warranty 3 Year(s)
מה שמסומן בשחור.
הגובה 37 סנטים תיבדוק עם מטר על המסך שלך.
