UT2K3 benchmark
עשיתי Benchmark ב UT2K3 וזה נתן לי את התוצאות הבאות:
36.557846
/ 123.925713 / 485.943878 fps -- Score = 123.983856 rand[8872]
21.583279 / 62.937614 / 131.921661 fps -- Score = 62.978226 rand[25671]
19.193110 / 53.686916 / 86.529709 fps -- Score = 53.702602 rand[11291]
18.974066 / 41.378807 / 132.699539 fps -- Score = 41.407475 rand[3792]
18.032282 / 51.546879 / 76.754509 fps -- Score = 51.563637 rand[14128]
14.531660 / 39.224377 / 72.212051 fps -- Score = 39.234100 rand[4714]
20.254124 / 61.646633 / 123.934105 fps -- Score = 61.697052 rand[9486]
14.699823 / 49.660770 / 110.999359 fps -- Score = 49.688972 rand[20354]
23.904324 / 52.131443 / 77.999039 fps -- Score = 52.143238 rand[12997]
18.412001 / 42.682896 / 101.970451 fps -- Score = 42.745819 rand[21044]
2.161294 / 64.969780 / 139.529343 fps -- Score = 64.968010 rand[14626]
22.244776 / 62.539925 / 121.982506 fps -- Score = 62.588547 rand[14162]
26.393278 / 60.056648 / 117.229996 fps -- Score = 60.089745 rand[15819]
17.060307 / 45.054695 / 83.409317 fps -- Score = 45.078022 rand[16547]
23.226654 / 39.298927 / 68.413666 fps -- Score = 39.325676 rand[6759]
15.702291 / 51.544182 / 98.171036 fps -- Score = 51.573067 rand[19522]
35.630058 / 79.733215 / 131.498947 fps -- Score = 79.783134 rand[31867]
17.054291 / 44.827755 / 98.276848 fps -- Score = 44.854847 rand[16038]
25.231453 / 60.638870 / 135.887604 fps -- Score = 60.677536 rand[11671]
11.416057 / 36.999035 / 80.633011 fps -- Score = 36.995205 rand[11244]
19.568380 / 45.412277 / 143.116119 fps -- Score = 45.423962 rand[18117]
14.187451 / 38.008091 / 99.331451 fps -- Score = 38.008690 rand[15346]
15.847940 / 41.490185 / 74.951477 fps -- Score = 41.499847 rand[25220]
27.955992 / 54.194172 / 117.642838 fps -- Score = 54.200127 rand[3514]
10.150982 / 43.927898 / 97.944122 fps -- Score = 43.933804 rand[23770]
מה זה אומר ? ומה זה אומר על הכרטיס שלי ?
שזה GF4MX
אל תלך לתיקיה BENCHMARK ותלחץ אל כל אחד
ץלך לתיקיה SYSTEM תלך על התוכנית BENCHMARK ושהיא תגמור לרוץ היא תביא לך תוצאה
נכון....
אבל מה חוץ מזה ?
מה משמעות המספרים ?
אם תוכל לפרט מעט אני אודה לך. :hi:
שזה GF4MX
לא יפה לצחוק על מי שאין לו רדאון 9700פרו,
לא נורא אני יקנה או את ה-NV30 או את ה-R9700PRO.
ואז לא תצחק.
Score = 123.983856
Score = 62.978226
Score = 53.702602
Score = 41.407475
Score = 51.563637
Score = 39.234100
Score = 61.697052
Score = 49.688972
Score = 52.143238
Score = 42.745819
Score = 64.968010
Score = 62.588547
Score = 60.089745
Score = 45.078022
Score = 39.325676
Score = 79.783134
Score = 44.854847
Score = 60.677536
זה מה שקורה שיש לך כרטיס לא איכותי.
זה הFPS שאתה מקבל
GF4MX הוא החולייה החלשה.
שלום
*הכותב צפה בחצי שעה שלמה של פנינה דבורין
**היה מאוד מעצבן למחוק את כל השטויות!
לפעמים בזמן המשחק ובעיקר שיש תנועה מהירה אני רוצה ריבועים קטנים שחורים.
זה בגלל הכרטיס נכון ?
:ylsuper:
אתה ממש רוצה אותם? אם כך, אני יכול להשאיל לך את הוודו 3 שלי. אני מבטיח לך שאיתו אתה תקבל את הריבועים השחורים שאתה רוצה.
;D
