צריך עזרה עם בחירת גרסא מתאימה לשידרוג BIOS
http://www.pcpartner.com.hk/bios/viabios.htm#pro133
Apollo Pro133
תבדקו שמה לפי הפרטים שלי מה אני צריך להוריד:
SiSoftware Sandra
Computer System
Manufacturer : VIA Technologies, Inc.
Model : VT82C692BX
Unique ID : FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
System Mainboard
Manufacturer : Vtech
MP Support : No
Model : 693-596B-8671
BIOS ID : 03/28/2000-693-596B-8671-2A6LGV3DC-00
System Chipset : VIA VT82C693 Apollo Pro Plus Chipset
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 512MB
Bank0/1 - BANK_0 : Empty
Bank2/3 - BANK_1 : Empty
Bank4/5 - BANK_2 : DIMM EDRAM 128MB
Bank6/7 - BANK_3 : Empty
System Chipset
Model : VIA Technologies Inc VT82C693A Apollo Pro 133 System Controller
Bus(es) : ISA AGP PCI USB SMBus/i2c
Front Side Bus Speed : 1x 133MHz (133MHz data rate)
Max FSB Speed / Max Memory Speed : 1x 133MHz / 1x 133MHz
In Order Queue Depth : 1 req(s)
Logical/Chipset Memory Banks
Bank 4 Setting : 128MB SDRAM 7-1-1-1R 4-1-1-1W 3-3-3CL
Speed : 1x 100MHz (100MHz data rate)
Multiplier : 1/1.33x
Power Down Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 3 : Micron THMY6480F1BEG-80 128MB 8x(16Mx8) SDRAM PC133U-333-542 (CL3 upto 133MHz) (CL2 upto 100MHz)
AGP Bus
Version : 1.00
Speed : 66MHz
Current Data Transfer Rate : 1x 66MHz (66MHz data rate)
Max Data Transfer Rate : 2x
Side Band Enabled : Yes
Aperture Size : 64MB
PCI Bus(es)
Version : 2.10
No Bridges : 1
PCI Bus 0 : PCI (33MHz)
Multiplier : 1/4x
LPC Hub Controller 1
Model : VIA Technologies Inc VT82C596/A/B PCI to ISA Bridge
ACPI PM Enabled : Yes
Random Number Generator Enabled : No
Multiplier : 1/4x
Speed : 8MHz
DMA Multiplier : 1/2x
DMA Speed : 4MHz
USB Controller 1
Model : VIA Technologies Inc VT82C596B USB Controller
Version : 1.10
UHCI Interface : Yes
Channels : 2
Speed : 48MHz
Legacy Emulation Enabled : No
System SMBus Controller 1
Model : Intel PIIX4 SMBus / compatible
Speed : 16kHz
Expansion Slot(s)
ISA : ISA 16-bit 5V FullLength
PCI (Fh) : PCI 32-bit 5V FullLength Available
PCI (10h) : PCI 32-bit 5V FullLength Available
PCI (13h) : PCI 32-bit 5V FullLength Available
PCI (14h) : PCI 32-bit 5V FullLength Available
AGP (8h) : AGP 32-bit 5V FullLength InUse (3Dfx Interactive Inc 3Dfx Voodoo Banshee Chipset)
Port Connector(s)
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO Compatible - Floppy / None
COM1 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB25 pin female / DB25 pin female
Keyboard : Keyboard Port - None / PS/2
PS/2 Mouse - Detected : Mouse Port - PS/2 / PS/2
USB : USB - None / None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Warning 231 : IOQD is set too low. Performance will suffer.
Tip 2525 : Current AGP data rate not optimal.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
נראה לי שזה
AP133MS1-907/
AP133MS1-C907 VIA Apollo Pro 133
(VT82C596B) (VT82C693A)
Micro ATX
35-8929-XX
35-C929-XX
awdf737 2K001023
- W83194R-39A
2K001219
- W83194R-39B
2K001122
- ICW-144
All Ver.
תעשו לי טובה תבדקו במחשבה שניה מה אני עושה לעזאזל אני מוריד עדכון של ציפסט? איך אני מוריד של הביוס כי יש לו דגם אחר - שמישהוא יסדר לי את הבלאגן בבקשה
- ולמה הזכרון שלי פועל ב 100MHZ ? יש לי ציפסט של 133MHZ ושקניתי בחנות אמרו לי זה 133MHZ
יש אפשרות לשנות את זה איכשהו? או שעבדו עליי?
הורדתי תקובץ הנל ובטקסט המצורף:
VIA-ApolloPro133 (ATX) Motherboard - Award BIOS
(VT82C693A+VT82C596B+ITE Super IO chip)
V1023IAG.BINFor Winbond (39A) Clock Gen IC
Oct/2000
V1219IAG.BINFor Winbond (39B) Clock Gen IC
Dec/2000
V1122IAG.BINFor ICW-W144 Clock Gen IC
Nov/2000
.2MBit (256KByte) Flash IC
.Different BIOS files for different Clock Gen IC support
Remark :
Please identify the clock generator IC on your motherboard before updating the BIOS. Upgrading with a wrong BIOS file may result in failure to power up after the upgrade !
לא יצא עדכון כבר שנתיים??
יש ללוחות של PC PARTNER מספרי דגם שלפיהם ניתן לזהות את הלוח.
זה אמור להיות רשום במסך הראשי כשמדליקים את המחשב.
