מה אתם אומרים על : ARCTIC COOLING Alpine 64 [כנסו]
Mfr Part Number: ACALP64
Features:
Extremely Quiet by Patented Fan Casing
Integrated Cooling of Voltage Converters
Patented Vibration Absorption
Perfect Cooling Performance
Easy Installation
Application: All AMD Sempron(Socket 754), Athlon 64 /64 FX /64 X2 and Opteron CPUs
Rated Fan Speed: 2000 RPM
Power Consumption: 0.17 Amp.
Air Flow: 36 CFM / 62 m3/h
Bearing: Fluid Dynamic Bearing
Noise Level: 0.6 Sone
Thermal Resistance: 0.26°C/Watt
Thermal Interface Material: Pre-applied MX-1 Paste
Dimensions (WxLxH):
Heat Sink: 98 x 78 x 56 mm
Fan: 101 x 113 x 47.2 mm
Overall: 101 x 113 x 91.7 mm
Weight: 486 g
הוא טוב?
