בעיה מוזרה בווינדוס
כשהמחשב עלה הווינדוס הודיעה על הבעיה הזאת:
a problem is preventing windows from accurately checking the license for this computer, Error code: 0x0004005
והווינדוס לא נפתח בכלל עקב התקלה. פירמטתי ועכשיו הכל בסדר, אבל מה זאת הבעיה הזו ומה אפשר לעשות בפעם הבאה?
נסה את זה
1. Restart your computer and press F8 to start in Safe Mode.
2. Log on.
3. Right-click My Computer and press Manage.
4. Open the Event Viewer.
5. Check the System event log by using the View menu to Filter for an Event source of Windows File Protection since the last time you successfully logged on. You should be able to locate the files that could not be found during logon, probably as Event ID 64005.
6. Using another Windows XP computer, preferably as the same service pack and hotfix level, copy the missing files. If you don't have another Windows XP computer, you may be able to Expand the missing files from the Windows XP CD-ROM.
7. Restart your computer normally.
8. You may have to reapply the latest service pack and hotfixes, perform a SFC /SCANNOW and also check for viruses and other malware
