מחפש מאוורר 80 חזק מאד ואפילו רועש אבל בזול
הכותרת אומרת הכל
לא איכפת לי רעש אלא שידחוף אוויר חזק אבל שהיה זול
אני מצאתי מאווררים ג'נריים (של Adda לצורך העניין), שדוחפים הרבה אויר, ומרעישים בהתאם.
there are generic 80mm fans for something around 25NIS at pandas (the cheapest I found in an on line store), but since the dilivery costs around 30NIS it probably won't be worth it.
btw, I got my 80mm for free from a store, they gave me a fried PSU, if you have a store nearby you can try it, maybe you'll get one for free.
just one small thing 80mm doesn't make that much noise, actually they hardly make any noise at all, 120mm however it a different story.
for someone with 7 fans I should know (4x45-nothing bigger fits,2x80,1x120).
