שאלה בקשר לצורב ASUS
שלום קניתי לפני מספר ימים צורב ASUS מדגם CRW-3212A
ונאמר לי שהוא תומך באיזה 2 טכנולוגיות שלא בדיוק הבנתי מהם עושות
1.Flextralink
2.flextraspeed
רציתי לדעת עם מישהו יכול להסביר לי מה הן הטכנולוגיות הללו!
תודה מראש!! ;)
up
FlextraLink:
Prevents users from buffer underrun problems caused by an empty data buffer, thereby eliminating the creation of unusable discs. Throughout the recording process, FlextraLink consistently monitors the data buffer status to ensure best recording quality. Once the available data drops below 1% of the total buffer capacity, FlextraLink suspends the recording and sets a marker at the last written position to avoid recording blocks. As soon as enough cache data is refilled in, the pickup head repositions itself to the marker and restarts the recording. FlextraLink uses minimal system resources so the PC remains full operational and available for other applications even during recording process.
FlextraSpeed:
Enhances accuracy and reliability when writing/re-writing across a broad base of certified media. It continuously monitors the recording media and sets the optimal writing speeds to ensure best recording quality. The built-in proprietary AI Auto Speed Adjustment Technology helps the driver function in the best status when reading across a broad base of certified media in different formats. It not only continuously monitors the reading media but also sets the optimal reading speeds. The latter greatly saves power and prolongs driver's life.
מקור: CDRinfo.
