חסרונות של לוח אם של ASROCK
תגידו מה החיסרון של הלוח הזה חוץ מה ה667
Model ConRoeXFire-eSATA2
CPU LGA 775 for Intel® Dual Core Pentium® D / Pentium® 4 / Celeron® D, supporting Core 2 Duo Desktop (Conroe), Presler and Cedar Mill processors
- FSB 1066/800/533 MHz
- Supports Hyper-Threading Technology
- Supports Untied Overclocking Technology
- Supports EM64T CPU
Chipset Northbridge: Intel® 945P
- Southbridge: Intel® ICH7R
Hybrid Booster CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
Memory Dual Channel DDRII memory technology
- 4 x DDRII DIMM slots
- Supports DDRII 667/533
- Max. capacity: 4GB
Slots Supports ATI CrossFire
- 3 x PCI slots
- 1 x PCI Express x 16 slot
- 1 x AGI Express slot (PCI Express x 4)
- 1 x PCI Express x 1 slot
Graphics n/a
Audio Realtek ALC888 7.1channel CODEC with High Definition Audio
LAN Gigabit LAN 10/100/1000 Mb/s
- PCIE x 1 Realtek RTL8111B
- Supports Wake-On-LAN
Connector 4 x Serial ATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Matrix Storage), NCQ, AHCI and "Hot Plug" functions
- 2 x eSerial ATAII 3.0 Gb/s connectors (shared with 2 SATAII ports), support "Hot Plug" function
- 1 x ATA100 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x Game header
- 1 x HDMI_SPDIF header
- 2 x IEEE 1394 headers
- CPU/Chassis FAN connectors
- 20 pin ATX power connector
- 4 pin 12V power connector
- SLI/XFire power connector
- CD in header
- Front panel audio connector
- 3 x USB 2.0 headers (support 6 USB 2.0 ports)
Rear Panel I/O ASRock 8CH_eSATAII I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x COM Port
- 1 x Parallel Port (ECP/EPP Support)
- 2 x Ready-to-Use USB 2.0 Ports
- 2 x eSATAII Ports
- 1 x RJ-45 LAN Port
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
BIOS Feature 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
Support CD Drivers, Utilities, AntiVirus Software (Trial Version)
Hardware Monitor CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU Overheat Shutdown to Protect CPU Life
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, CPU Vcore
Accessories Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 100 cables
- 4 x SATA data cables (optional)
- 2 x SATA 1 to 1 power cables (optional)
- 1 x HDMI_SPDIF cable (optional)
- 1 x USB+1394 bracket
Form Factor ATX Form Factor: 12.0-in x 8.6-in, 30.5 cm x 21.8 cm
OS Microsoft® Windows® 2000/XP/XP 64-bit/Vista compliant
Certifications FCC, CE, WHQL
הכל ברור ,חוץ מעל איזה לוח אתה מדבר לעזאזל???
תשנה את הכותרת בהתאם לחוקי הפורום
ואם אפשר שתהיה בעברית הפעם
